The manual crank is usually on the opposite side from the the the way the slide moves. It will be 3/4 inch nut, on a shaft usually. With the slide out, look at the 2 support rails. The manual crank access is generally in line with one of the rails, just inside of one of them.. Most often, the front one, but not always. May be just under the edge of the siding, or may find an access hole in the siding, with a rubber plug covering the hole. Don't have a Sunseeker, and can't recall working on one lately. The suggestions I gave are generic, for any camper with an electric slide.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
