Old 06-24-2018, 11:51 AM   #1
Thumbs down Which battery starts my genset?
I want to service my genset (Cummins Onan RV QG 4000) on my Forester. The instructions say to disconnect the negative battery cable at the battery. My question is which battery serves teh genset, the house battery or the truck battery? Thanks
jackdaddy is offline   Reply With Quote
Old 06-24-2018, 12:18 PM   #2
2012 Solera
On my Solera, the house battery.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-24-2018, 03:00 PM   #3
or disconnect the cable on the generator.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 06-24-2018, 07:02 PM   #4
My genset always takes more than one attempt to start it. My house batteries drop in voltage when I start the genset.
This is a good idea to disconnect.... It is so easy to accidentally hit the start switch while working on the genset.
sask is offline   Reply With Quote
Old 06-25-2018, 12:26 PM   #5
Kirk S's Avatar
Normally the generator is started using the house batteries. If you have the emergency start switch, activating it can allow the generator to be started from the vehicle battery.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 06-25-2018, 12:50 PM   #6
Citrus County, Fl.
GL1800Rider's Avatar
sask, if you are having trouble starting yours do what I do. Open the generator door and you will see 2 rods on top of the carburetor. One of them goes into a box ( I imagine for the governor) on the right. See if that rod will move to the left (front of the motor home)
I check mine before we leave and it's ready to go when needed. Prime about 10 seconds and now it starts on the first try. I have to do this whenever the generator is cold.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 06-25-2018, 12:52 PM   #7
Duckogram's Avatar
Servicing the genset or just changing the oil? For servicing, I pull the negative cable off the house batteries. For changing the oil its a waste of time. YMMV
ILB ( | )
Old 06-25-2018, 12:55 PM   #8
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered as you can see.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-26-2018, 01:34 PM   #9
I'd be very leary of disconnecting the neg cable at the generator. The battery connects to the chassis as does the frame of the genset. While you probably won't have a problem, it's a lot safer to disconnect at the battery.
Disconnecting the positive lead at the genset is even worse. Once disconnected, you have a "live" heavy duty positive wire that's loose and could easily come in contact with the frame, creating a dead short across the battery. Anybody want an unexpected arc welder?
Phil
pmsherman is offline   Reply With Quote
battery
