03-18-2017, 05:26 PM
? White poles in cabinet
Does anybody know what the small white metal poles are for. When we were looking at the 3011ds we noticed them either in a cabinet or sitting on a table.
03-18-2017, 05:41 PM
Do they have rubber ends like a cane? If so maybe I can help we had them in our 2860DS Sunseeker they were used to prop the end of the bed up when the slide is in. Just incase someone sits on the end of the bed I guess.
Now for my question we now have a 3051S Forester and it has a longer bed but we didn't get any poles. Do the new ones come with poles to support the bed? If so I am missing mine. Hope this helps both of us.
2017 3051S Forester
03-18-2017, 06:30 PM
You didn't say how big. If they are about 3/8" diameter and have springs in them with rubber ends, ( See photo) They are probably Fridge bars. They are to put across the door of the fridge to keep items from moving around or falling out while traveling.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-18-2017, 06:36 PM
Ok mine are not small like Flybob posted. I took small to mean short mine are about 1" diameter. I will have to look in the refrig and see what we have in there. I just learn something new everyday on here.
2017 3051S Forester
03-18-2017, 06:52 PM
Slide out bars, used to keep the slide in.
03-19-2017, 08:10 AM
The bars should be used if the slide fails and you have to manually put the slide in. These bars would then be used to keep the slide in while driving.
03-19-2017, 08:18 AM
DW's 401(k) Plan
X3 ^^^^
To me, they are a little disappointing. I liked the adjustable slide out bars a lot better. I've already had one of the new type become dislodged in transit and drop down between the side and the facia of the slide out. DW didn't realize this and extended the slide, which in turn, pushed the facia trim out a couple of inches. Simple fix, but still......
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
03-19-2017, 12:28 PM
Fridge bars
03-19-2017, 01:03 PM
Slide out bars if you have a problem with the slide not staying in when driving.
Happy Campin!
Forester 2451s
03-19-2017, 11:22 PM
The foot of the bed on the 3051s is designed to slide under the closets when the slide is in. We even pull our bedding back off the foot of the bed to make sure we have enough clearance when we bring in the slide.
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
03-21-2017, 08:38 AM
Class C Representative
We refer to these poles as "Slide Stoppers" in case your slide fails and you need to manually bring the slide in. If the slide fails you will need to manually crank/push the slide in and stick these poles between the slide and interior wall of the motorhome.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
03-23-2017, 10:32 PM
Hey.. Mr. J. Cavitt how many poles do you get per unit ? Thanks Tony
03-24-2017, 08:17 AM
Depending on the floor plan you may not get any. We only use them on Schwintek and power gear slides in which you would only receive two per slide.
03-24-2017, 08:41 AM
I have 2017 2861 DSF found only one "Slide Stopper". Thanks Tony .
