Winterizing 3010ds
Hello
I just returned (to NY) from a trip to Florida. Started to winterize the unit again. Drained low point, emptied water heater, set the bypass for the water heater, removed the filter, got the hose to pump the antifreeze through the system, turned on the water pump and it went on but no suction. I tried everything. I missing something? Any help is appreciated. (When I winterized it in November all worked well with no issues including pumping antifreeze through system using water pump)
Michael
2019 Sunseeker 3010ds
