Old 09-29-2015, 08:05 PM   #21
Originally Posted by vwexpert View Post
Where did you guys splice into the air bag hose? ...and did u leave the stock filler valve stems to use as backup if the air pump system goes fails for some reason.
Jim
I installed Tees (one for each side) in the existing line where it ran from the stock inflation to the air bag. I did leave my stock valve in place and connected.
System has been flawless. Even with the additional lines ran for the WirelessAir my pressure holds steady according to the remote display. When my coach is parked I turn off the power to the compressor. I occasionally check the pressure with a gauge at the inflation stem and it is holding just like the remote shows.
Bobby
bgilly is offline   Reply With Quote
Old 09-29-2015, 08:08 PM   #22
papap's Avatar
I tied in where ever it was easiest to do it. I left the old valve stem so I could air it up with an air compressor
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 09-29-2015, 08:16 PM   #23
ourflat's Avatar
Here's a pic....
Frank
KM4FVI
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 09-29-2015, 08:28 PM   #24
vwexpert's Avatar
That is what I was going to do but just want to make sure
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
