01-18-2018, 11:37 PM
Wood stain
Has anyone found a good color match stain for the Cherry cabinets?
Dave W AKA "Toyman"
Well modified Forester C 2551
Why ?...Why not ?
01-18-2018, 11:55 PM
I tried to find that too. Never got anywhere. I will be watching this space.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
01-19-2018, 06:38 AM
When I needed to match the stain of my Hickory cabinets I removed a small cabinet door and took it to a paint store. Sherwin Williams matched the factory stain and I finished the project without delay.
01-19-2018, 06:54 AM
Also the thing to remember is the "Wood" that is used for most of our "Cherry Cabinets is Not Cherry! The cherry Stain/Wash they use will Vary Greatly when used on different Species of Wood! If you take a existing Cabinet door for a color sample also take a sample of the Wood you are going to use! I agree with using Sherwin Williams! Youroo!!
01-19-2018, 07:07 AM
Also used Sherwin Williams to match ours. I used pine and plywood for my dinette project and it matched fine. I rarely run out of stain because it goes a long way but it gets old and wants to be thrown out but I keep the lid to retain the store info in case I need another can mixed up.
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
01-19-2018, 08:18 AM
Excellent suggestion to take in a sample but do be aware the product they use is a tinted lacquer (or quick dry varnish) that sits on top of the wood and does not penetrate into the wood like a stain does.
My point is if you ask for a stain you may not be getting the product that you want.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
01-19-2018, 09:32 AM
Hmmm? It had been suggested to me to go to Sherwin Williams too but when I called to see if I could do this they told me they can't do that. Too many different types of wood, or some 'put me off" answer like that. I guess I'll try again.
P.S. I see CedarCreekWoody's point and that may be part of the issue I had. Asked for stain and should have asked for tinted lacquer.
2018:16
Total 239
01-19-2018, 09:36 AM
And don't forget a lot of our "WOOD" is really printed paper. At least in my Rockwood it is.
2018:16
Total 239
01-19-2018, 10:20 AM
You might look at this on Amazon, or similar tinted lacquer with a Google search:
https://www.amazon.com/dp/B0009XCLEQ...ing=UTF8&psc=1
Most refinished mix their own. You might try local refinishers if you can't find a paint store to do it.
PS If you hire a local painter to come in and finish your new bare wood cabinets he will be spraying tinted lacquer. Perhaps a call to a painter can give you ideas for sources.
Andersen hitch
01-19-2018, 01:51 PM
What your referring to is what I call "Plood"! This can come in Paper covered wood or Plastic covered wood! Youroo!!
01-19-2018, 03:01 PM
I’ve found Minmax “Red Chestnut” to be a pretty close match. I put a door in the space above the microwave and can tell the difference if you linger on it but close enough for me. I use that color in the “pen stain” for touch-ups also.
2015 Sunseeker 2300 Chevy
01-19-2018, 03:54 PM
If you are building something out of wood, be sure to take a few scraps of that wood with you when you go to match it. If using a laminated product, take care to insure the all visible surfaces come from the same side of the product.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-19-2018, 03:56 PM
Perhaps mix your own? I've done this several times. Find a Minwax oil stain that is close. If spraying mix the stain in lacquer. If brushing mix the stain in oil base (not water based) varnish. Mix slightly on the light side. Apply a coat and check the color. If too light apply another coat. More coats equal darker color.
Spraying does the best job if you have the equipment and know how. Apply light coats!
Andersen hitch
01-28-2018, 02:51 PM
I re-made my slide out fascia over the bed and used cherry wood. To my surprise, cherry doesn't take stain evenly and will darken and lighten over time. I spoke with Minwax and they recommended applying their stain conditioner. I probably made 10 stain sample boards trying to mix the right combination. I ended up using Red oak, Red Mahogany, Red Chestnut, English Chestnut and cherry. It was such a mess trying to get it correct, I lost track of the exact amounts of each. I also tried Sherwin Williams and brought them a piece of cherry. Theirs when applied didn't match well because of the cherry wood and it's absorption properties.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
01-28-2018, 05:16 PM
Cherry is notorious for splotching with penetrating stains, hence the reason tinted lacquer is so popular with manufacturers.
Andersen hitch
