Old 06-21-2015, 07:10 PM   #21
I have the GasBuddy app but it doesn't do nothing as far as convenience of pulling a 35 foot trailer into a station
Rgsa8892 is offline   Reply With Quote
Old 06-26-2015, 12:22 AM   #22
Send a message via Skype™ to chuckw5kav
My DW and I have traveled I-5, I-84, I-90, I-15 with a 33ft
5th wheel and never had a problem with a Flying J, or Pilot
and a couple of TA truck stops for fuel. Most all the Pilots
we were at had both gas and fuel at the same pump, this
of course if you use one of the truck lanes which only
have fuel and no gas.
If you happen to pull into the back where trucks fuel look
closely at the 1st line closest to the building, this is usually
set up for RV's at the bigger truck stops and have both
fuel and gas.
If you pull up to a fuel island that has three pumps, two
across from each other and one pump back about 30ft
form the two other pumps that single pump set back is
for refer fuel, do not use this pump, it is for refer and
off road use only and can cost you allot of money in
fines if used in your truck.
2017 Durango Gold G384RLT
Coachmen Owners Association
2005 Ford F350 Dually
W5KAV
Last years Camping 125 days
chuckw5kav is offline   Reply With Quote
Old 06-26-2015, 06:08 AM   #23
EastlakeRoo's Avatar
Used Pilot Flying*J and the pull thru RV Lane made fueling easy with no obstacles. Not sure if every Flying J is set up the same but the ones in Indiana were great. In and Out quick.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 06-26-2015, 06:34 AM   #24
when I pick my trip. i go to flying j and look on there web site and plain my route .so I know when to get fuel and food. they are the easiest to get in and out of.
wire1946 is offline   Reply With Quote
Old 06-26-2015, 06:55 AM   #25
check out your enterance and exit befor you pull in, then take as much room that you need, most poeple are patient, good luck, try not to get traped and have to back out maybe concider a larger gas tank
Big Bill is offline   Reply With Quote
Old 06-26-2015, 07:39 AM   #26
Phat Phrog Stunt Crew
elind's Avatar
I just returned from a Michigan to Arizona trip and used a lot of Flying J's for fuel. I started going to the trucker's pumps but then found many of the J's had RV lanes with gas and diesel. You just needed to watch the entrance signs to find the RV lanes.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 07-11-2015, 06:41 AM   #27
Pilot Flying J has an app for your phone called myPilot that gives you map with the stations and what services they offer, number of truck lanes, rv lanes, dump station, discount card accepted/not, what restaurants are inside, etc. While you are driving your copilot can use it to see how many miles until you get there and the exit name and number and detailed directions (like turn left .2 miles, destination is on your left, etc.)
Shows the current gas, DEF and diesel prices free app and always up to date.
Brentf is offline   Reply With Quote
Old 09-03-2015, 11:35 PM   #28
TriGlide's Avatar
Yep me also... Great stops...
TriGlide is offline   Reply With Quote
