Old 03-31-2016, 08:11 PM   #1
Question about "grades" around Yellowstone
We are heading out to Yellowstone this summer and are planning our travel route. i have never driven in this neck of the woods, let alone with a large TH (XLR 29HFS). We are coming from the east going around the north side of Yellowstone and staying near the west entrance. We will then be traveling south to the Grand Tetons staying at Colter Bay. We will then be heading back east to more flat land.
Just curious how steep the grades really are on our planned route (see attached...)
Thank you for your responses/suggestions...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-01-2016, 06:19 AM   #2
Oakman's Avatar
To be honest, your map image is so small I canít tell what roads you are taking. Perhaps you could upload a larger map of your route.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-01-2016, 06:41 AM   #3
RSchleder's Avatar
You'll find 6% just about the max grade. Not really a problem, however, more so when going down the grades. Don't ride the brakes, let the transmission gears in vehicle do the work of holding you unit's speed down and hit the brakes to slow you the rest of the way down and then get off them so they can cool down.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-01-2016, 09:13 AM   #4
Jim34RL's Avatar
An old truckers rule that has been hand down on the Turbo Diesel Register web site; is what ever gear you pull up the hill in, that is the gear you go down in.
I normally pull in 5th gear up most 6% or greater rises and stay in the same gear going down. But I have one of the newer 6.7L Cummins with the VGT turbo and exhaust brake which will really slow me down.
In your case you have a 6.0L gas engine and I do not know if you have a 6 spd auto or not, but you may want to try a lower gear than drive when climbing a 6% slop. So this way when descending the rise you can control the load through the drive train using engine braking.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 04-01-2016, 11:50 AM   #5
Rivnut
Rivnut's Avatar
yellowstone driving
Be mindful of the northeast entrance from Cody, the Bear tooth pass is 10,900 ft, long hard pull hard on tow vehicle.
Rivnut is offline   Reply With Quote
Old 04-01-2016, 12:00 PM   #6
D_B Travelers's Avatar
We pulled our WJ 3001w through the Grand Tetons and Yellowstone last year with a 1500 Sierra, 5.3 ltr. and really had no issues. We came in from the west but left out the east side. You have a little bigger engine and the heavier frame. Don't think you are going to run up the grades at 65 MPH with no trouble, you can but the engine will be screaming in 3rd gear @ 4100 RPM. I was told by GMC that this wasn't an issue as the computer will not let you hurt the engine, however I usually topped the steeper grades in 4th at about 3100 RPM, which was around 50 MPH. About the same speed as any larger trucks you will see. DO watch downhill and use the manual shift feature to keep your foot from riding the brakes. We loved it and hope you have fun too!
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 Ė 1996)
D_B Travelers is offline   Reply With Quote
Old 04-01-2016, 12:01 PM   #7
Also, use your Tow/Haul mode when descending in a lower gear. Your RPM's will be higher, but the engine will help slow you down. Just make sure you have good brakes before leaving. We just replaced ours and it makes a huge difference.
gfarmcafe is offline   Reply With Quote
Old 04-01-2016, 12:23 PM   #8
geeman53's Avatar
We came from the south on US191 to Jackson,Wy. pulling a 5thwheel . No problems at all. We also stayed in West Yellowstone,Montana. Stay far away from Beartooth when towing.We went to the top of Beartooth Mnt. in the pickup ,not towing. Us 191 to us 212 was hilly, to Devil's Tower was back the way east for us.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 04-01-2016, 12:57 PM   #9
Just A Member
EDABEUT's Avatar
Looks like you plan to take I-90 out and I-80 back for a round trip. We did just the opposite from Michigan. Out on I-80 and back I-90 thru Wisconsin and the UP. The only grades on the whole trip that I was concerned with was from WY into SD. I took I-25 south from Buffalo WY and a 2 lane thru Ten Sleep to Mt Rushmore. Not sure what Mt range it was called but it was pretty hairy. Really glad I had hill descent mode on my TV it really worked good and hardly had to use the brakes. I toke this route on purpose to give myself a challenge.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 04-01-2016, 12:58 PM   #10
camaraderie's Avatar
Driving a classA gasser with NO toad..would you guys who have done it coming from the east go straight in from Cody on Rt.14 or choose another route? Is Beartooth both up and down or is it mostly up going in and mostly down heading back east? Aside from the grade.. is the road wide enough & in decent condition? Thinking about coming in that way and leaving from the south through Grand Teton but I could either swap that road choice or use the same one in and out.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
