03-06-2019, 01:36 PM
Redding CA to the coast
We are planning a summer trip and I have a question about CA 36 from I-5 (south of Redding) to Fortuna CA. How is that road and should a newbie have any specific concerns? Ford F250 6.2L gasser, 4.3 gearing, towing a 31' Wolfpack toy hauler GVWR 9985#. Thanks.
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2017 DR-Z400 SM
03-06-2019, 06:02 PM
You could do it but a better bet would be to take 299 west from Redding. 36 has a lot of tight turns on the east end and is only 1 and 1/2 lanes wide for about 10 miles with no center line.
03-06-2019, 06:22 PM
Thanks! Exactly the kind of information I was looking for. We will probably do 36 on the bike after parking the trailer!
2015 DL1000A ADV
2017 DR-Z400 SM
03-06-2019, 06:35 PM
Some years back I was pulling a 14,000 lb 5ver with a Ford V10 on that hwy. The turns forced me to slow down and I lost my RPM's. I could not get the RPM's up to get any torque. Good Luck.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
03-06-2019, 07:00 PM
Are you speaking of 36 or 299?
2015 DL1000A ADV
2017 DR-Z400 SM
03-06-2019, 07:03 PM
299
2019 Rubicon JLU
03-07-2019, 11:21 AM
I go across 299 several times a year with my 15,000# 5er with no problems at all. My truck is a 2005 Dodge megacab with the 6.7 Cumings an 4.10 gears.
03-07-2019, 01:43 PM
Right. But the OP has a gasser. Huge difference at low rpm's.
2019 Rubicon JLU
03-07-2019, 01:47 PM
That's what the trany is for, just gear down.
03-07-2019, 01:54 PM
In my case I was in 1st gear floored! Still not enough torque to get up on the torque curve.
2019 Rubicon JLU
03-07-2019, 02:34 PM
wow you must be geared really high. Is your truck 4 wheel drive? If so you might try using low range.
03-07-2019, 02:48 PM
Not so Capt. The truck was a '99 Ford F350 CC LB 4.33 gearing with the new V10 gaser towing a 14,000 lb 5ver. Gasers need high RPM. No RPM, no torque. Since that time I've had all diesels and never looked back.
2019 Rubicon JLU
03-07-2019, 02:49 PM
Oh, and it did have 4wd and I did consider dropping down to Granny.
2019 Rubicon JLU
03-07-2019, 02:57 PM
299 is a better drive than CA 36, when towing.
03-07-2019, 09:29 PM
Recommend Route 299. Also very scenic, but well maintained, wide for a two-lane, and fairly easy grades. Recommend River Walk RV Park near Fortuna. Very nice and easy day drive into Ferndale, which you must see.
03-08-2019, 12:41 AM
The difference is you have a diesel and he has a gasser.
Diesels get their max torque around 1600 RPM, gassers closer to 5000. At lower RPMS his engine does not create the torque yours does.
Why do you think all the big rigs are diesels?
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-08-2019, 01:27 PM
Thanks for all the responses. Looks like 299 will be fine. I'll travel with the tanks empty and only one ADV bike in the garage, so hopefully will be well under the Wolfpack GVWR.
2015 DL1000A ADV
2017 DR-Z400 SM
03-08-2019, 02:06 PM
There are a couple of long fairly steep pulls on 299 but you should be able to keep your speed up.
03-08-2019, 09:44 PM
One must have equipment needed for the job. I don't think using low range 4WD on pavement is a good recommendation.
03-09-2019, 12:13 AM
I would only use it if there were no other way unless I had locking hubs in the front then I would unlock them and it would not be a big deal because it would by like you were in two wheel drive.
