Old 04-01-2012, 12:03 PM   #1
Replacing black water waste valve on 2010 georgetown 330ts
I am in New Mexico with a leaky waste water valve. Need to replace valve. Camping World quoted me two hours to fix it. Does anyone have any experience with problem?
grant is offline   Reply With Quote
Old 04-01-2012, 12:55 PM   #2
First are you able to empty the tank?
The valves are bolt in place, if you are able to empty it the part are available almost anywhere (RV supply store) Valtera has the part for replacement.
http://www.valterra.com/RV/rv-main.htm
The second option there is a twist on valve that can be applied and get you home.
TWIST ON VALVE
Have you ever delayed fixing an old valve problem? Now just twist a new valve onto your current waste valve bayonet fitting and eliminate messy replacements or expensive service!
T58PART NO.DESCRIPTIONPRICET58Twist on valve24.03
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 04-01-2012, 12:57 PM   #3
TURBS's Avatar
if you are somewhat knowledgable and handy with tools its really not a bad job at all .
biggest problem is dealing with the smell and trash that potentially comes out when removing.
theres only a few screws that holds it all together . you have to be very careful when reinstalling new valve that the oring does not move out of the recess .
grease or vaseline works well to hold it .
Old 04-01-2012, 01:01 PM   #4
Here is a quick video link..
Bill M
Old 04-01-2012, 01:06 PM   #5
If your tank is empty and flushed with clean water it is a very easy job that would take at the most one half hour. I am sure you carry the basic tools for this easy job. If they tell you it is a 2 hours job I have serious dought about this long charge of 2 hours? Unscrew the 4 bolts. slide the old valve out and reverse the procedure for installation. Good luck
capucine is offline   Reply With Quote
Old 04-01-2012, 01:43 PM   #6
caper's Avatar
The 2 hour charge is most likely including dumping and a good flush of the black water system. They do not want any surprises when they start to replace the valve.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-01-2012, 04:20 PM   #7
backin15's Avatar
I replaced one in my last camper, it was a 20 minute job. As long as you do a good job of flushing the tank it is not a big deal.
backin15 is offline   Reply With Quote
black water
