Old 04-29-2016, 12:38 PM   #1
dmdomokos's Avatar
Routes to Grand Teton NP Colter Bay from Las Vegas
We will be taking a trip to Grand Teton NP Colter Bay (then Grizzly RV Park) coming up from the south through Las Vegas. What is the best route to Colter Bay. I15 through Idaho Falls or I80 to 16 to 30 to 89? or ?? We have a 32'TT towing it with a Suburban 1500 so steep grades are not our friend.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
dmdomokos is offline   Reply With Quote
Old 04-29-2016, 03:54 PM   #2
I would take I15 to 26 to 89 to 191. Do not take the shortcut over Teton Pass from Idaho Falls to Jackson.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-01-2016, 03:31 PM   #3
Blackrock's Avatar
I came down to I-80 the way you are planning on going up via I-80 to 16 the north. Not a bad route really. Going to be a fair pull out of SLC to the I-80/I-84 junction.
On up to Idaho Falls is good as well. But as Ibrjet mentioned go 26 - 89 - 191. Teton pass is way steep. Beautiful but STEEP.
If you need to overnight in the Idaho Falls area may I recommend the county owned park near Shelly. North Bingham Park
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-07-2016, 08:22 AM   #4
lytlej's Avatar
The 30 - 89 route is pretty good. You can avoid Parleys Summit out of Salt Lake City buy going to the northern suburb of Ogden and cutting over to I-84 and head back south to I-80. There is a long hill once you get back on I80. One pass on US 89 but is fairly short. 89 is the most scenic route to Yellowstone. If you are willing to do 2 more passes get on US 89 at Salt Lake and go through Logan, UT. There take the Logan Canyon to Bear Lake to Montpelier. You won't regret the views. That is my favorite route. As you pass under the Worlds Largest Elkhorn Arch in Afton, WY honk, I'll probably hear you.
lytlej is offline   Reply With Quote
Old 06-07-2016, 10:11 AM   #5
dmdomokos's Avatar
We are leaving in a month, thanks for all the route advice. We will plot our route with this new info. We will honk!
gas
