Old 10-06-2015, 11:01 AM   #31
Originally Posted by OldCoot View Post
Need to try Trail Ridge Road, it goes higher than Pikes Peak and go across the suspension bridge. DO NOT ATTEMPT TO TOW anything.
Suspension Bridge? where is a suspension bridge on Trail Ridge Road?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 10-06-2015, 11:08 AM   #32
If I was you I would run across some CAT scales.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-06-2015, 11:39 AM   #33
Fulltime family RVer
I scaled back in June and also did individual wheel weights about the same time. We've made some changes since then- removed stuff, added stuff, etc. So my numbers should be pretty close to accurate.
Old 10-06-2015, 12:17 PM   #34
Oakman's Avatar
Well, we made it to Avon, CO (just west of Vail) last night. We didn't leave Colorado Springs until after 6pm and had to stop for propane after that. Our whole drive was in the dark. As you all said- not bad, just take it slow. Between the exhaust brake and downshifting, I actually had to often accelerate down a hill or two.
But now- going up some grades, I could do 60-65mph but on some of the steeper grades, the truck was maxed out at 45-50 mph. My pedal was to the floor and I couldn't go any faster. The truck is a 2012 Ram 3500 with 4.10 gears. It's GVWR is 12,300 and I think I'm running down the road loaded at 12,300-12,500 with us, pin weight, and stuff in the truck bed. The camper is 42' X 13' 4" high and has a total loaded weight probably around 16,000 lbs.
My real question- is this performance up hill what I should expect? I can't say what I expected as I've never towed heavy before this.
I certainly canít say with authority, but I think maxing out at 50 MPH with the load you are pulling is probably normal for the mountain grades you traveled. Donít forget, wind speed also affects performance. It seems as though every time weíve headed west the headwinds were always terrible.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 10-06-2015, 11:26 PM   #35
I can say that I was passing big rigs up these hills. Not by a lot, of course.
Old 10-12-2015, 02:40 PM   #36
LANShark42's Avatar
Garden of the Gods
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 02-01-2016, 09:39 PM   #37
The I-70 corridor can be like rush hour traffic in the summer. (And winter with ski traffic)Avoid Friday afternoon and Saturday morning going westbound, and Sunday noon to 8 pm east bound.
I've pulled my 12000# fifth wheel with a GMC 2500 diesel no problem. Truck will even pull Vail pass eastbound @ 65 mph which is faster than I care to go.
If you are underpowered, keep your eyes open way out front. Once you get trapped behind a slow moving vehicle it will be very hard to get back your speed when towing.
Randy-2198 is offline   Reply With Quote
