I have had the BIRD replaced but I think there is an issue and it may be connected incorrectly.
Does anyone have a photo of the BIRD ( under the steps above the batteries ) that would show the connections it would be very helpful. I think 04 – 06 could be the same.
I have an '04 370TS in storage that I will be bringing home on Friday to get ready for Spring. If I haven't seen a reply to you by then, I'll take a picture and post it. It certainly won't be as clean as in your picture though, so I hope the details will be viewable. What caused you to have to replace yours by the way? I'm just wondering if it has a wear out issue I should be concerned about.
Hopefully you will see two attached .jpg pictures. Both are essentially the same view, each will slightly different contents than the other. I wasn't sure what you were looking for. Hope these help.
