Old 12-29-2014, 06:26 PM   #1
10g Hot Water heater Electric Switch
2008 Georgetown 373ds. First post. Did a search and didn't see this addressed. Has anyone tried or is it possible to move the electric rocker switch on the 10g hot water heater to somewhere inside the coach? Can't figure out why this wasn't done when built/installed? Sure would be easier just to switch on or off inside when needed. Thanks
Milehghcty is offline   Reply With Quote
Old 12-29-2014, 06:43 PM   #2
Tim & Lisa Trempert
It is already there. It is in your circuit breaker panel.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 12-29-2014, 08:51 PM   #3
Going to try and remember that!
kb5sej is offline   Reply With Quote
Old 12-29-2014, 08:53 PM   #4
mud yapster's Avatar
LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 12-29-2014, 09:00 PM   #5
just.a.jeep's Avatar
I put a illuminated switch on the wall near the breaker panel. Just run a wire from the breaker to the switch and attach the wire, that was on the breaker, (from the heater) to the switch. The switch is literally in series with the breaker and the heater. This gives you indication and you don't have to open the breaker panel.
Don
Cedar Creek 36CKTS (400watts of solar), 2012 Ram 3500 Laramie
2014 Cedar Creek 36CKTS 2012 Dodge Ram 3500 LARAMIE
just.a.jeep is offline   Reply With Quote
Old 12-29-2014, 09:43 PM   #6
abjb's Avatar
Here's a thread by Iggy.
Added switch for Hot Water Heater inside
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 12-30-2014, 08:58 AM   #7
Duh ... the breaker switch. Why didn't I think of that! Also thanks for the link on the switch ... might go that route ..
Old 12-30-2014, 09:38 AM   #8
Denver, CO
garbonz's Avatar
Breaker's are not really designed to work as switches, and will eventually quit working, so a switch is a good idea, especially if you are switching on and off often.
2017 Fuse 23T
Old 12-30-2014, 10:19 AM   #9
May be wrong, but by turning off breaker doesn't it cut power to electronic ign for running on propane also ?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-30-2014, 10:29 AM   #10
TURBS's Avatar
Electronic ignition for propane is 12v.
electric, heater, hot water, water, water heater
