Old 05-29-2017, 01:31 PM   #1
Newellri's Avatar
12 volt problems
My control panel in my Rv has gone dead! I have power coming into the electric panel. If I check the fuses with a meter I have 12 volt from one side of the fuse to the housing, but nothing across the fuse. I think I must have lost my ground but I have no idea where it would be. The lights work but the drivers seat does not. Georgetown 350ts 2012. Thanks for any help. After rereading -- the electric panel is the 110/12 electric box and the control panel is the panel for water heater and slides and etc. thanks again.
Newellri is offline   Reply With Quote
Old 05-29-2017, 02:07 PM   #2
Pull out the fuse and test it.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 05-29-2017, 02:21 PM   #3
Newellri's Avatar
Ok
Old 05-29-2017, 02:28 PM   #4
MacGumbo's Avatar
Model# or pics of the panel?
2020 Grand Design Reflection 240 RL
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
MacGumbo is offline   Reply With Quote
Old 05-29-2017, 03:42 PM   #5
Newellri's Avatar
Checked the fuses and they are good.
Old 05-29-2017, 03:49 PM   #6
There was a recent post about some of these failing; they have a recall on them but no new parts yet. Don't know if yours is one of the affected ones.
2011 Traverse LT, 3.6L, FWD
Old 05-31-2017, 10:07 AM   #7
Newellri's Avatar
The power for the slides is dead but the water heater works. The slide power will work momentarily. This makes me think it is a bad ground. The good news the slides finally went out before going clear dead. The bad news we can't get them back in to take it to dump the tanks. Also the state of Iowa has taken the dump station out of the I35 rest area that is close to us. Now I have to pay at the truck stop. Lol. Thanks for the help.
Old 06-04-2017, 04:50 PM   #8
Newellri's Avatar
I found this behind the electric panel does any one know if this runs the slide outs.
Old 06-04-2017, 04:51 PM   #9
Newellri's Avatar
Thanks for any help!
Old 06-04-2017, 07:15 PM   #10
Attachment 140112
It is a 12 Volt DC, 40 Amp Single Pole Single Throw D87 Relay made by Hella in China.
Now I have no idea what it is hooked up to other than a 12 volt DC circuit.
Never seen one before in my rig.
Old 06-04-2017, 10:08 PM   #11
Newellri's Avatar
Thanks Iggy will look for a replacement if the other fuse is not it.
Old 06-05-2017, 11:12 AM   #12
Newellri's Avatar
Found a replacement and it didn't help, bummer!
12 volt
