02-11-2013, 06:57 PM
12 volt water pump wiring?
Since my georgetown does not have a pour spout to add fresh water except from a garden hose with pressure, I decided to buy a 12v Remco pump to use while dry camping and pumping water from the 6 gal jugs. Am going to use alligator clips on my jeep battery for the dc 12 power, but not sure what gauge wire I can use. Is the low voltage, irrigation wire ok? MM
02-11-2013, 07:38 PM
It is probably a 10 amp pump and #14 guage is ok.
Why do the method you discribed?
If you have a sysytem that has a extra hose coming off your pump that is used for pumping antifreeze into system can be used.
Just open the end of the spare hose off the input side of the pump and turn the T valve to other position. This will make the pump suck whatever is at the open end of the hose into your rig.
If you have no idea what I said you can PM directly and I will explain more.
02-11-2013, 07:39 PM
Denver, CO
How many amps does it draw? And how many feet of wire?
Chart Below.
12 Volt DC chart
Ampsin WireWattsat 12V#14#12#10#8#6#4#21/02/03/01128413120633753222442661031682664326754481833528413321633754367567214223356891412253604505708961016274266108168272338427101208.513223353841352182703421518068.51322355690144180228202406.610162742671081351712530081322335486108137303606.6111828457290114404808132133546785 These are one-way distances, measured from point A to point B. The out and back nature of electrical circuits has already been included. For PV arrays, figure the entire run, from the panels to the charge controller to the batteries
2017 Fuse 23T
02-11-2013, 07:40 PM
Denver, CO
Whoops, picture not so good.
2017 Fuse 23T
02-11-2013, 07:44 PM
Denver, CO
New Pic
Here is the chart FYI, but you probably can get away with #14 AWG (lamp cord) You will want to use stranded wire , as it is more flexible and can be coiled.
2017 Fuse 23T
02-11-2013, 07:51 PM
You would have to run a hose from a faucet to your FW tank though in order for it to fill. The bypass only fills the lines and bypasses the tank completely.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
02-11-2013, 08:29 PM
Originally Posted by ttrost65
you would have to run a hose from a faucet to your fw tank though in order for it to fill. The bypass only fills the lines and bypasses the tank completely.
yes
02-12-2013, 07:51 PM
thanks for the ideas. I agree with Iggy, I recently winterized using that hose and pump and I think it bypassed the fresh water holding tank and went directly to faucets. Matt
02-22-2013, 12:36 PM
My remco pump worked fine. The 6 gallon jugs emptied in 2 minutes.
02-22-2013, 05:14 PM
The $40 Harbor Fright does about five gallons in the same amount of time.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
03-13-2013, 06:13 AM
Yes, but Harbor Freight sells chinese junk, (pun intended), the Remco is made in Minnesota, and is working fine.
03-13-2013, 06:34 AM
I have a 50 gallon hard tank in the bed of the truck and also a collapsible 45 gallon tank that I use a 12 volt pump to put water into my fresh water tank. I do have a dedicated filling port for that on the 5er. I just hook the alligator clips to the battery cables of my 5er and it works fine. The pump came with the wiring and clips. I'm sure it would work just fine in your situation.
