Old 08-04-2016, 12:51 PM   #1
12Volt Interior lights out
On a recent trip, my bedroom wardrobe light, and the 2 directional lights above the bed quit working (These are on the slide-out). I'm thinking fuse (they seem to be wired off of each other) It's hard to trace the wiring, because it's all concealed. Any idea where the fuses are for the interior 12Volt lighting?
Appreciate any input...
TX
B
2004 342 XLS Georgetown
2004 Suzuki Intruder
2009 Pontiac G6 GT
bear52 is offline   Reply With Quote
Old 08-04-2016, 02:21 PM   #2
Weekender
Ford1's Avatar
I can think of two possibilities. The first is in the main fuse/breaker box that is usually located in the bedroom near the floor. Normally you just remove the cover and the breakers (for 120vac) and some fuses for 12VDC are exposed for changeout. The other location is normally under the stairwell, located on the frame rail is a power control box. You will have to remove the cover thereby exposing additional fuses. Hopefully, the one you need to find is in one of these locations.
Mike
Ford1 is offline   Reply With Quote
Old 08-04-2016, 02:58 PM   #3
Mike,
TX.....I've checked the + coming into all the fuses on the floor panel, and I've got + going thru all the fuses. I'm also thinking under the stairs because all the 12V lights run off the coach battery. Unfortunately, these things don't come with detailed fuse distribution drawings. TX again for your reply
B
2009 Pontiac G6 GT
Old 08-05-2016, 09:17 AM   #4
WhoDoMan
If check your GFI outlet in the bathroom and reset it. Stranger things have been wired by FR.
whoDoMan is offline   Reply With Quote
Old 08-05-2016, 09:20 AM   #5
The 110v GFCI breaker would have nothing to do with the 12v lights.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-05-2016, 02:10 PM   #6
Retired Ford Tech
12 volt lights
Since your unit is a 2004, I would trace where the wiring goes into the slide. Every time the slide goes in and out, it puts flexes in the wiring. I did a lot of wiring repairs at door jams on cars.
rvpezzano is offline   Reply With Quote
Old 08-07-2016, 12:14 PM   #7
Well, it's fixed. I figured why all 3 lights in the slideout? So, as there is not any visible wiring outside the slide, I said...maybe under the bed. Broken wire. Actually, it came out of the plastic crimp. Don't know why after 12 years, but...
They give you absolutely no "slack" in this wiring, so I added a foot of 12 guage wire, and life is good. TX to everyone.
B
2009 Pontiac G6 GT
light
