Old 04-06-2011, 11:33 AM   #1
bend302's Avatar
15 amp power
In our storage unit there is a 115V 15 amp outlet. If I get the appropriate adapter would there be enough power to leave the Motorhome plugged in and charge the batteries? I know I would need to turn all of the other AC electric stuff off.
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 04-06-2011, 11:54 AM   #2
I have heard it's not good to keep the batteries constantly charging while in long term storage. I've been told it's better to disconnect them and bring them home.......charging them at home once a month or so. The constant charge and topping off kills them faster?
We did however keep our TT plugged in, except for winter, for the fridge. The batteries on our TT only lasted 3 years.
GrowingGoatee is offline   Reply With Quote
Old 04-06-2011, 11:59 AM   #3
CLASS "A" Senior Member
cfsoistman's Avatar
You would be better off buying a Battery Tender and leaving the coach unplugged, disconnect the batteries from the coach and hook the Battery Tender to the batteries. The other way you stand the chance of boiling off the batteries. The Battery Tender will maintain the charge without boiling the batteries.
Battery Tender - Home of the Battery Tender Jr. - Batterytender.com
They are available at plenty of stores. I think Walmart might sell them as well.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 04-06-2011, 12:02 PM   #4
Hey there cfsoistman. I clicked on that link and my Norton Security went nuts and shut me down. Bad site with viruses.
Old 04-06-2011, 12:11 PM   #5
cfsoistman's Avatar
That's strange I'm at work and no problems at all. Maybe Google Battery Tender and see the other links from some of the retailers. You should be able to see them. I know they're sold on Ebay as well.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 04-06-2011, 12:13 PM   #6
I keep my security setting pretty high. Kids. It could just be a tracking cookie? But, when the computer shuts down....it's usually an attack.
Old 04-06-2011, 12:41 PM   #7
Depends on what kind of battery charger is built into your onboard system. For example - the electrical panel unit in our 2010 8315BSS has a modern 3-stage charger as part of it. If yours is the same, then IMHO you can safely leave it plugged in as it will maintain your batteries the same as a Battery Tender would. Your documentation should tell you what this info.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 04-06-2011, 06:43 PM   #8
Bend 302, I have a 2007 Georgetown 370 and I keep it plugged in from April thru October and never boil the batteries, In the winter months I keep the coach unplugged and run the coach once a month for an hour along with the gen set. Plug in you will be fine.
370xl is offline   Reply With Quote
