Old 03-20-2012, 11:51 PM   #11
thanks this what Ive been looking for the light bar.is it 12 volt or 110 .we have a 378ts 2012 model.mom says no light in kitchen area.
petey is offline   Reply With Quote
Old 03-21-2012, 09:43 AM   #12
senforex's Avatar
We have a G378 (2012) and if you push the ''light'' on the Frigidaire microwave/convection oven there is a light under it.
senforex is offline   Reply With Quote
Old 03-21-2012, 10:11 AM   #13
TURBS's Avatar
Looks good I wish I was handy with wood!
Old 03-21-2012, 10:36 AM   #14
raoulwv's Avatar
I did a similar light mod in my 378, only I used a 12v ceiling light (purchased at Camping World) that matches the other lights in the coach. I'll post pics when I get the chance (coach is in storage right now). Also, I'd be happy to explain my install, if anyone wants to go the 12v route.
Rod & Carla B.
The Hounds Kooper & Abby
2015 Sunseeker 3010; '14 Ford Focus toad
raoulwv is offline   Reply With Quote
Old 03-21-2012, 12:59 PM   #15
Send a message via Skype™ to Falcon35
gartonhl and raoulwv:
How did you get the wire through to the light?
Did you drop the microwave?
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 03-21-2012, 02:16 PM   #16
Pete
gartonhl's Avatar
No.....I didn't drop the MW oven.
There is a 1/2 inch space between the right side of the MW and the left side of the cabinet. I ran/fished the LED light plug through that space and through the hole that was cut for the MW plug on the left side of the cabinet.
I was lazy! We were enjoying our camping too much and didn't want to get into a protracted install of the light. I may run the plug on top of the MW later, but you really can't see the cord unless you look up under the molding that I installed to "somewhat" cover the cord up; or unless one is short enough to see it while standing in front.
Hope this helps....
ID:	11083   Click image for larger version
Pete and Patty
2010 Georgetown 378TS; 2012 4dr Jeep Rubicon
1 Yellow Lab (hers);1 Little Bitty dog (mine)
gartonhl is offline   Reply With Quote
Old 03-21-2012, 02:37 PM   #17
raoulwv's Avatar
No, I did not have to drop the microwave. I did have to remove the piece of wood trim above the microwave though. What I used to remove it was a steel rod that was narrow enough to fit between the microwave and the cabinet beside it. I then bent the end of the rod 90 degrees so I could get it in behind the trim and pop that end loose. The trim was attached with some brad nails that I couldn't reuse so cut them off flush. I found that the trim fit very snug and I really didn't need them anyway. Besides the light and wiremold I installed held it in place ( you'll see when I post the pics).
To connect the light to 12v, I popped the light fixture out under the cabinet next to the microwave. I then used a drill with an extra long bit and angled it through the opening to drill a hole in the side of cabinet that is hidden by the microwave. I then snaked a wire through the hole and over the microwave. I notched out the top of the wood trim I removed earlier for the wire to fit in. When it was all done, It looked like it had come from the factory that way (which it SHOULD have).
Rod & Carla B.
Old 03-21-2012, 05:32 PM   #18
Thank's: gartonhl and raoulwv,
I think I will go with 110 after I get home.
Right now we making our way home from RGV and have an appointment with Forest River in Elkhart on April 2 for some adjustments that the dealer can't or won't do. Then we are going to Lima OH to visit family before we go back to Ontario.
2008 Honda Fit
Protect-A-Tow
Old 03-22-2012, 02:40 PM   #19
raoulwv's Avatar
Just curious gartonhl: How did you get the plug between the MW and the cabinet? Does the cord unplug from the light?
Rod & Carla B.
Old 03-22-2012, 04:44 PM   #20
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
I cut the plug off and then spiced it back on after I got the wire thru the hole.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
378ts
