Old 02-23-2016, 10:54 AM   #11
Who Dares, Wins
doc73's Avatar
I have had a few Fords over the years have issues with the park override switch (or something called like it) that keeps the vehicle in park unless the brake is pressed. Needed to put it into neutral then start because it did not require the brake to be pressed to start then shift into drive. I still pressed the brake but the vehicle's would at least get me going.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-23-2016, 11:54 AM   #12
Originally Posted by Paul S. View Post
I believe the rear suspension has a spacer under the left rear spring that raises that side higher. It was installed for another application but was never taken out for this application. I have a 2007 373ds and it leans to the pass. side. I am planning on removing it this spring.
I stated the same thing in his other thread that he started.....he will most likely have a 2 inch spacer in the left rear spring....I am finding Forest River to be less than helpful when you question them about anything. I asked about this issue and their wonderful sidewall separation fiasco....no response
Carmen is offline   Reply With Quote
Old 02-23-2016, 02:18 PM   #13
Is your passenger side 2-3 inches lower?
badge2283 is offline   Reply With Quote
Old 02-23-2016, 02:49 PM   #14
Yes, close to 3 inches on the passenger side
Old 02-23-2016, 03:22 PM   #15
jergeod's Avatar
Originally Posted by Dijoeboss View Post
This isn't my issue, I was merely trying to help someone that is having an issue.... But thanks for the helpful insight!
2013 Georgetown XL 350
Bunkhouse
2002 F250 4X4 CC
2012 Jeep Liberty
No that wasn't for you, I used your response and highlighted the area for the op sorry
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
georgetown
