Old 07-31-2015, 05:40 PM   #1
2000 Georgetown battery wiring
I have a 2000 Georgetown. The batteries were taken out. I have put it a new chassis battery but the coach won't start. Nothing at all. I have a white wire left over. Thought it was on a coach battery but it could be related to the battery store control. I think it goes on the Plus. Any help would be appreciated.
A wiring diagram would really be helpful.
DougA98 is offline   Reply With Quote
Old 07-31-2015, 07:23 PM   #2
waiter21's Avatar
Do the headlights work?
what about radio, heater, etc when the key is turned on?
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
waiter21 is offline   Reply With Quote
Old 07-31-2015, 08:45 PM   #3
I had been working on it during the day so I had to go out to try. But no lights or radio. I think it may be the store but where does the white wire go. Do you know where I might get a wiring diagram
Old 08-01-2015, 10:35 AM   #4
waiter21's Avatar
According to the diagram on my 2001 chassis, there are no white wires that connect to the battery.
THOUGHT - Do you have a "STORE/USE" switch for the chassis battery?
I'll take a look at my MIrada when I get home. It'll be a couple hours.
Old 08-01-2015, 01:49 PM   #5
Thanks for the reply. I think the store is just for the coach batteries which are not installed. The white wire is heavy but like a stranded #10 . I think it may be a ground for the steps.
Thanks again for your responses. I'll keep looking for a wiring diagram.
Old 08-01-2015, 07:33 PM   #6
waiter21's Avatar
can you trace the white wire back and see where it goes.
battery, georgetown, wiring
