Old 01-27-2015, 09:55 AM   #1
TomW's Avatar
2006 340 Georgetown
Just bought this unit and really like it.
Need to know where to get several Georgetown decals as they are sun damaged.
What type hydraulic oil is used in the system?
Thanks!
TomW is offline   Reply With Quote
Old 01-27-2015, 10:39 AM   #2
RudysWorld's Avatar
My 2011 350 has a Lippert system and they call for Type A Automatic Transmission Fluid, ATF with Dexron III or Mercon 5 are recommended
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 01-27-2015, 04:28 PM   #3
TomW's Avatar
2006 340 Georgetown
Thanks Rudysworld
Old 01-28-2015, 09:10 AM   #4
Iggy's Avatar
Welcome and you found the best place to ask question about your Georgetown.
I use the cheapest ATF at Walmart.
ATF with DexronIII and Mercon 5 if you plan to replace and flush the system.
I think its never good to mix different ATF fluids and I'm sure the factory or past owner used the basic ATF because of the costs.
The level in the tank should be about 1/2" to 3/4" from the top of the tank when everything is up and closed. If you over fill you will get leakage out the filler cap and that's messy.
You may be able to get new stencils from Forest River.
You can call them and ask but I suspect it will be expensive.
Here is some contacts.
Kevin Stratton
Forest River Warranty Georgetown
Phone: 574-206-7611
Fax: 574-206-2484
kstratton@forestriverinc.com
Forest River Parts Dept. 574-262-2212
Dan Evans – Parts Department
Contact Phone: 574-206-7605 or 7600
Contact Email:
devans@forestriverinc.com
Good luck
Old 01-28-2015, 11:00 AM   #5
TomW's Avatar
Thanks Iggy, appreciate your help
TomW
Old 01-28-2015, 06:54 PM   #6
jergeod's Avatar
These guys beat me to it answering your questions but I have the same 06 340tsse as you.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 03-05-2015, 06:43 AM   #7
Decals I toke the decals off and had a good cleaning and and buffing done.
Ange is offline   Reply With Quote
georgetown
