Old 09-06-2012, 09:13 PM   #11
2012 Solera
For this type - where the metal ring and lense come off together - I found that by slipping a thin screw driver blade in under the outside edge of the metal ring, twisting it slightly, and working all the way around the ring doing this, I was able to loosen the lense/ring unit sufficiently to remove it without damage.
Old 09-06-2012, 09:16 PM   #12
Originally Posted by Iggy View Post
Great idea about using vasoline or some type of non-flamable non-petrolium base lube
Vasoline is petroleum based, I would use a silicone grease.
Old 09-08-2012, 08:54 AM   #13
I still haven't gotten mine off. I can twist the chrome and glass back and forth but for some reason it won't drop off.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 09-08-2012, 10:32 AM   #14
I've tried a rubber strap wrench but no joy. I'm beginning to think someone has glued all these lights in my MH except the one over the sink which kept falling off.
May try the thin screw driver suggested by JLeising
rgfenner is offline   Reply With Quote
