Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Motorhomes > General Motorhome Discussion > Georgetown
Old 10-03-2010, 03:56 PM   #1
2011 Georgetown 350 7 pin hitch socket
I am looking for some help with the location of the fuse supplying the hot wire to the 7 pin socket on the back of my 2011 Georgetown 350. Specifically, I am trying to find the location of the fuse or breaker supplying pin 4 (at the 2 oclock position) in the socket. The pin is hot all the time even with the key off. The owners manual for the Ford chassis lists the loads for the fuse panel in the cab and the fuse panel in the engine compartment but doesn't seem to include this load. I have removed several of the fuses associated with "trailer / tow" loads but none of these supplied power to this pin. The hot wire doesn't appear to be wired directly to the battery unless it is at a junction I can't see.
I am going to install a charge line to my toad to maintain the Toad battery during extended pulls. I have a Blue Ox Patriot supplemental brake unit in the Toad. I will be using a Toad-Charge unit to regulate the charge and prevent back feed. I want to determine the fuse / breaker size of this hot wire.
Is anyone aware which fuse / breaker (and location) supplies the charging pin? Any info would be appreciated. Thanks
snoway95 is offline   Reply With Quote
Old 10-03-2010, 04:14 PM   #2
cfsoistman's Avatar
Welcome to the forums and congrats on the new Georgetown. I'm not sure where that fuse is located. I do know there are fuse boxes under both the dash and the hood. You may want to connect a test light to it and start pulling fuses related to the tow harness until the light goes out. It may be on with another item and just isn't labeled. Good luck and please post your findings. I haven;t have the need to check everything out but maybe someone else has and will post their findings.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 10-03-2010, 08:11 PM   #3
I found out unexpectedly that relay #2 and maybe others are part of the tow harness wiring system.
2010 373DS
Master Tow with 2008 Nissan Altima
bresdogsr is offline   Reply With Quote
electrical, georgetown 350ts, wiring harness
Close [X]
