Old 04-29-2014, 10:46 PM   #61
GABoy's Avatar
Originally Posted by ttincali View Post
Pretty sure the Santa Ana's we get regularly out here (in fact as I speak at 70mph gusts) are much worse than anything you experience in the midwest! - I lived in the Detroit area for 30 years and never experienced winds like we have out here - but for sure don't miss the cold, snow & salt!).
I did a little research on the 2014 F53 frame (which I have) and ours comes equip'd with a front track bar, wondering if this is why mine seems to handle well stock? Did the pre 2014's have this front track bar?
I also have a 2014 351ds, thats what the title of the gt shows, but the title of the Ford chasis shows it as a 2013. Where did you find out about a track bar on the ford frame? The frame title calls it a F5DR.
GABoy is offline   Reply With Quote
Old 04-29-2014, 11:04 PM   #62
GABoy's Avatar
Nevermind, found the specs for the 2013 frame online and it does show the track bar standard for the front.
Old 04-30-2014, 07:29 AM   #63
Originally Posted by GT4six View Post
I sure will, once I get. I'm just a bit leery of the fact that they first sent me the right model with wrong brackets, which leads me to believe they are not keeping up with models. Ours is 2013 which could be a 11 or 12.
how big of a ride difference was after installing it?
Now that you say this, I wonder if I received the correct brackets but not the bar. I can't remember exactly how much I had to cut off, but I think it was about an inch. I contacted them with the issue and they never got back to me so I took care of it myself. Something else that crossed my mind was that maybe the rear axle was installed a little off center and why the bar wouldn't fit. I couldn't verify it, and not sure if it's possible for it not to be centered.
You know how the rear end is constantly swinging and has the feeling that you are in a boat. Well, by securing the axle to the frame yet allowing it to move up and down, you get rid of most of it. The biggest improvement we noticed for our coach was the CHF and the correct tire pressure. I would say the correct tire pressure or CHF is no.1, then the Tiger Trak is no.2 Not sure about a steering dampener since we don't have one. I did order front Konis and we will see what they do for the ride.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 04-30-2014, 07:36 AM   #64
Wow, that is very windy. So, with winds like that, let's say 30 mph winds, your coach doesn't get pushed? We also have a 2014....well, the coach is 2014, but I'm willing to be the frame is either 12 or 13. Ours also has the front trak bar, and without any mods it would get pushed by winds, truckers passing, and bad roads. It has improved little by little with the correct tire pressure, CHF, and rear Trak bar. Not sure what the difference is between your coach, ours, and a lot of other folk, besides wheel alignment. Ours is a 351DS.
Old 04-30-2014, 03:28 PM   #65
I still need a hand doing the CHF. In ft lauderdale now headed home to md on Friday.
k3wtf is offline   Reply With Quote
Old 04-30-2014, 04:32 PM   #66
I'd gladly give you a hand with it if I was closer. It's so easy to do that I did ours on a campground. I initially did it at home and traveled to FL only to find out our wheels where off the ground a couple of inches. It was a spot with a bad slope and we were there for a week. I disconnected the links to let the tires drop and then reconnected them before we left. I always carry some common tools and that's all that's needed. You don't even need to apply Loctite since the nuts are self locking.
Old 04-30-2014, 06:05 PM   #67
I got off passenger side but could not get bolt out on drivers side. Even with a bottle jack could not move bar to get close to going in back holes.
Old 04-30-2014, 06:50 PM   #68
I could move ours about a 16th of an inch with my hands and it took very little effort with a bottle jack. I think it's time to take it to a mech to get it done.
Old 04-30-2014, 07:58 PM   #69
abjb's Avatar
Take both bolts out before trying to raise the bar, start with the driverís side.
Spray some WD40 on the bolt.
If you use a jack donít lift the bar MUCH, Ĺ inch or so.
Hereís a picture with a guaranteed way to get the bolt out donít damage the threads.
Luck
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 05-02-2014, 09:58 PM   #70
Happy Member
GT4six's Avatar
I guess I'll find out when I get the whole package replacement. I will let you know since I will be able to compare one set with the other...and furthermore, I should be able to make a god comparison of what you mention which sounds very logical....tire pressure, CHF, tiger Trak...next up the steering.
Me, DW and final score...
2 Girls-2 Boys
The lazy nanie K9
2013 FR GT 351DFS
GT4six is offline   Reply With Quote
