Old 07-27-2016, 02:02 PM   #11
If I had a Class A, I would carry an unmounted spare tire, and tube if it needed one.The service truck may or may not have a tire suitable for your RV, and who knows what the price will be?
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 07-27-2016, 02:12 PM   #12
I agree with RamblerGuy, carry an unmounted spare tire. For 10 years, I carried an unmounted spare in the trunk of my towed car. But I never used it. But it gave me a sense of security if having a flat. If I had a flat, I planned to call road service because of the weight of tire and lug nut torque of over 700 lbs. When calling road service regarding a flat, they may ask if you have spare. If not, the road service tech will bring a spare of the correct size. But they may charge you any price, usually over priced.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 07-27-2016, 03:08 PM   #13
RVnut's Avatar
I can say from experience that prices are priced just like at the store for the tires but they usually charge a $100 service fee..
Problem if you carry a spare and dont use it for 10 years it is past if life expectancy of approx 7 years so you wasted the money
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 07-27-2016, 04:13 PM   #14
Commercial Member
You are correct on the price. It is also true that some sizes may be hard to find (it may take a couple days to find the correct size in some cases)
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 07-27-2016, 04:28 PM   #15
SeaDog's Avatar
The one flat I had on my Class A when I called road assistance they asked if I had a spare and was it inflated.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-27-2016, 06:50 PM   #16
Class A Spare Tire
Why spare tires don't come with most Class A's always intrigued me. I have an '04 Cross Coutry on a Freightliner chassis. There was enough room between the rails and behind the fuel tank to mount "L" shaped steel bars to nest a full size mounted wheel in between. It sure did come in handy last year as a rear inner tire had a blowout. I called roadside and swiftly they arrived to our aid. The roadside tech told me that we saved a lot of time by having a complete wheel setup as its not always convenient to acquire our particular tire size and wheel should the wheel been damaged after the blowout. He told me that although you have a large truck tire but the actual rim/wheel is not as easily acquired being slightly different dimension than the wheels that are typically on large tractor trailers or town equipment .
So locating the correct wheel sometimes can delay getting you back on to your travels.
Johnnyboy is offline   Reply With Quote
Old 07-27-2016, 07:35 PM   #17
With my Vista we had a spare.
When we did have a blow out, we were not ripped off for the price of a new one while on the side of the road.
Wish we had a spare on this Georgetown.
Paperbill
paperbbill is offline   Reply With Quote
Old 07-27-2016, 08:37 PM   #18
Hello: Just wanted to input my opinion; Had blowout this past April coming back from Key West. Contacted local tire repair / replace company, waited 5 days for a new tire after dealer said old tire was not serviceable. Seems that certain times of the year in real areas these 22.5 Michelin tires are hard to obtain. I now carry a spare tire (without rim) with us on our travels.
Seabee MC
Seabee-MC is offline   Reply With Quote
Old 07-27-2016, 08:49 PM   #19
I have the GT XL 352QS. If carry just the tire with no rim, it has to be kept in the basement which will take up some room or may not even fit.
If carry it under the chassis behind the gas tank, it must have the rim otherwise it will collect all type of debris which ends up killing the tire before I need it.
That said, has anyone carry either full wheel or just the tire with your G'town and how did you carry it?
Tam & Ha
Willis, TX
2016 Georgetown XL 352QS
2011 Jeep Grand Cherokee
2016 Nights Camping - 6 nights and 2 shake down and love it...
tamdle is offline   Reply With Quote
Old 07-27-2016, 10:04 PM   #20
Roadmaster now sells a spare tire carrier that mounts on your tow hitch. It includes a 2" drop fitting so you can still tow a toad or trailer. The spare mounts on a hinged bracket and there's a separate extension bar to give you enough leverage to easily (with some effort) to raise and lower the tire from/to the ground.
I can't speak for 22.5" tires but the 19.5" tires on my Georgetown can be changed without external assistance. I rotated (swapped) my front tires this past May before starting home, an 1800 mile drive. Fortunately, my lug nuts are only tightened to 150 ft-lbs and a 24" breaker bar is long enough to loosen them. I also carry a torque wrench for tightening them.
pmsherman is offline   Reply With Quote
class a, tire
