Old 04-04-2015, 08:31 AM   #1
borba's Avatar
2Questions washer/dryer combo
hi I need advice I wanted to buy washer/dryer combo should I buy vent our ventless and also how hard is to install a vent thank for your help
frank
2015-georgetown 378xl
2013-ford fx4
2009-harley flhx
borba is offline   Reply With Quote
Old 04-04-2015, 08:37 AM   #2
BillMFl's Avatar
Personally, I choose not to have a washer/dryer in my MH. But if you do, you don't want all the added moisture from the dryer dumped into your MH.
BillMFl is offline   Reply With Quote
Old 04-04-2015, 08:43 AM   #3
We love our vented Splendide.
Lostdog
2011 Georgetown 378TS in FireMist
2013 Jeep Wrangler Toad
Kirby the Old Dog, passed but still in our hearts
Max E. Dog, the new pup
Eureka the Old Cat, still hangin' on
Lostdog is offline   Reply With Quote
Old 04-04-2015, 08:59 AM   #4
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
We have the vented Splendide in our Silverback....we had our dealer install it but the installation doesn't appear to be that complicated.....got to use it on a recent Gulf Coast trip for 7 days and you learn to take your time washing and drying loads and don't overload....we set ours to wash only and then at the end of that cycle it reminds you to go get the things out of the washer, shake out the wrinkles, and return them then for the drying cycle...if not, they tend to dry in a ball.....don't think the DW would do without it now....returning home, washing is out of the way...just one less thing to do.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 04-04-2015, 10:20 AM   #5
Grape Escape
Would not even consider non vented model. DW loves her combo Splendid.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 04-04-2015, 01:30 PM   #6
Iggy's Avatar
X2 on the vented.
Just to let you know that it is designed for smaller loads than home.
As the manual says don't wait until you run out of closed before you start washing as it takes longer to wash and dry.
We usually do small loads on day 4 or 5. Socks underwear.
Jeans and shirts you have to plan for a longer drying time.
Anyway you already are paying for the water and electric so you just sit back and enjoy your location and don't rush the washer. lol
I attached the manual which you should read completely.
Good luck
Old 04-04-2015, 02:35 PM   #7
borba's Avatar
thank you all for your help vented thanks Iggy for the manual
sill cant figure forest river prepare everything accept the vent out
thanks
frank
2013-ford fx4
2009-harley flhx
Old 04-04-2015, 09:12 PM   #8
BillMFl's Avatar
thanks
frank
Just a guess but most GT owners are probably not full timers and have much less need for a washer/dryer. If I were a full timer or close to it I would have a vented model.
Old 04-05-2015, 07:49 AM   #9
Tim & Lisa Trempert
I believe a ventless model vents through the drain pipe and not into the motor home.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 04-05-2015, 08:46 AM   #10
Phat Phrog Stunt Crew
elind's Avatar
The vent less unit has a condenser that converts the moist air back to water and dumps it down the drain. It's like a dehumidifier in a house.
I just installed a vented unit in my 5er the other week. Everything was in my RV for hookups except the vent. The only issue I had was the venting because it was our front bedroom closet. The closet was shallow and the 4" vent pipe only had 2 inches of room behind it. Then the vent needed to go the floor of the closet which was tricky. I did get it to work after adapters, cutting through walls and floors in the end. If I was doing it again the vent less is would be an easy install. But if was doing the vented unit again I would pay Camping World the flat rate $79 to install it. But I didn't have that option.
Oh! The Splendide does work good, just smaller loads.
2014 Wildcat 327ck
elind is offline   Reply With Quote
