Old 10-16-2015, 05:36 PM   #1
30 amp vs 50 amp
Sorry for the stupid question but we are new to all of this. We have a 2012 37' Georgetown and have not sure what our amp is. When going to RV campsites we seem to always use the 50 amp spaces and have no issues. I know when home we use a converter to hook up to the house. We are looking at a campsite that offers just 30 amp...is this ok?
bvbullock is offline   Reply With Quote
Old 10-16-2015, 05:50 PM   #2
Iwannacamp's Avatar
You will need a 50 to 30 amp adapter and will only have 30 amps service.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 10-16-2015, 05:52 PM   #3
thanks...will everything still work with 30 amp? Not sure what the difference in service would be
Old 10-16-2015, 06:05 PM   #4
Iwannacamp's Avatar
Just not as much useable amperage as 50. This time of year unless you are running 2 a/c units I doubt you would ever need more than 30 amps. JMO
2017 Puma 297RLSS
Old 10-16-2015, 06:30 PM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
As long as using one ac you are good to go on 30amp Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-17-2015, 12:33 PM   #6
With 30 amp. One AC and run hot water on propane typically works.
Harkerr is offline   Reply With Quote
Old 10-17-2015, 04:46 PM   #7
30 amp vs 50 amp
Keep in mind with 30 amp service you only have 30 amps total for all electrical items in you MH. With 50 amps service you have a total of 100 amps for everything.
So just add all of your electrical items you want to run at one time and don't exceed 30 amps.
Some of the items are:
1 AC 15 amps
Residential fridge 8 amps
Lights up to 8 amps
Water heater 15 amps
Hair dryer 15 amps (wife's nessecity)
TV 2 to 3 amps
Like Harkerr says use the propane for the water heater will help a bunch.
So you see it can add up fast.
Just keep it under 30 amps.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 10-17-2015, 05:09 PM   #8
Tim & Lisa Trempert
Wrapper man, can you explain the 100 amps? Is thus because it's 50 at 240v so at 120v it's double that? I just bought a home with 30amp and I was wondering if running a 2nd 30amp service and using a pigtail I saw online would be the same as 50amp. Sounds like it wouldn't be as it would only be 60 amps and not 100 amps?
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 10-17-2015, 05:31 PM   #9
Fulltime family RVer
In my uneducated view of the world- 50amp service has 2 legs of 50amp service on each leg.
So, two 30amp legs would be close but not the same.
ependydad is online now   Reply With Quote
Old 10-17-2015, 05:33 PM   #10
Yes.
For a MH
30 amps: 1 branch120 volts 30 amps. Total 30 amps
50 amp: 2 branches each 120 volts 50 amps. Total 100 amps
For residential homes a 30 amps circuit is (most of the times) 240 volts.
Never think you can connect to a 30 amp circuit, like a dryer, to a 30 amp MH. You will fry all of you appliances and electronics.
Your MH needs to be connected correctly.
On this site Iggy has great information on how to connect a 30 amp circuit for your MH. Just run a search.
I'll try to find some articles and post them.
2008 Honda CR-V
50 amp
