Old 09-14-2017, 03:31 PM   #1
31l5 tire pressure
Can't find it in the manual, but what tire pressure are all of you running in your tires.
dcluvtohunt is offline   Reply With Quote
Old 09-14-2017, 04:57 PM   #2
i have a 351ds, based on my loaded weight I should and do keep them at 90 psi
KEliasz is offline   Reply With Quote
Old 09-14-2017, 05:01 PM   #3
Thank you
Old 09-14-2017, 07:54 PM   #4
I weight my 2017 31l5 and the charts showed 80 PSI all the way around.
kyinger is offline   Reply With Quote
Old 09-14-2017, 08:11 PM   #5
Thanks.
Old 09-14-2017, 09:25 PM   #6
I have a 2013 378 and the chart says 85 one the rear and 80 in the front
My tires are 255/80-22.5"
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 09-15-2017, 04:41 AM   #7
cjd10's Avatar
351DS and mine are at 92
2014 Georgetown 351DS
Charleston SC
1 Boston Terrier, 1 Frenchie, Two Siamese
Gonna miss you Toby, Sage, and Izzie. RIP
cjd10 is offline   Reply With Quote
Old 09-15-2017, 07:52 AM   #8
Thanks to everyone for your input. We appreciate the knowledge.
Old 09-15-2017, 08:19 AM   #9
JimF's Avatar
Look up the tire pressure/load chart for your tires. Weigh your unit and you will have the correct pressure for your unit.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
Old 09-15-2017, 07:23 PM   #10
HookupAndGo's Avatar
Any reason not to go higher?
I usually run mine at 95 -- and regrettably have to admit I have not weighed my 351ds.
i (maybe erroneously) run higher to improve the wear on the tires. But again, could be wrong.
2013 Georgetown 351
Much more significant other....
2 Kids and a dog that rules!
HookupAndGo is offline   Reply With Quote
Old 09-16-2017, 08:18 AM   #11
JimF's Avatar
Ride comfort, with to much pressure the coach rides like what it is, a commercial truck chassis. There isn't really any available data that says running higher pressure extends tire life any appreciable amount. It can cause handling issues. Your tires will age out way before you need to replace them based on mileage.
Safe Travels.
Old 09-16-2017, 03:35 PM   #12
Dennis King's Avatar
I have Georgetown 2017 364 TS and CW installed Tire Sensor system! They put 114 in front and 110 in rear! I am leaving for Waco tomorrow! Anyone else have same vehicle and what do you use? Thanks for any help on short notice!
Dennis King is offline   Reply With Quote
Old 09-16-2017, 05:43 PM   #13
I've solved the problem of not being able to check the outside tire PSI without taking off 2 lug nuts and the chrome cap covering the wheels. Camping World has valve stem extensions (not the flexible ones) that are bent at a 135 deg angle. Part #8029135. I've just installed them and they work great. You do have to take off the wheel cover to install and line up with the opening, but then checking PSI and adding air is a breeze. All my tires were set to 75 PSI from the dealer, but I'm going with 85 for the time being. Thanks to all for your input.
Old 09-16-2017, 07:44 PM   #14
Anyone with a Georgetown 364TS no tow vehicle
How much air do you put in? I see the lable says 90 lbs cold pounds but Camper World just put tire sensor system that tells temperature and has it at 114 on front and 110 in rear? Should I drop to 90 pounds?? Leaving tomorrow at 1.30 for Waco from Cinci and I know it may be hot!!!
Thanks for any help!
Old 09-16-2017, 07:54 PM   #15
I have a 378XL. My front axle weight is 5800/tire and rear 7500/ tire. The weight chart says 78psi for front ties and 83psi for the rear tires. My tires are 255/80 22.5"
Your pressure sounds high but it may have smaller size tires. Check your maximum psi rating on your sidewalls.
2008 Honda CR-V
Old 09-16-2017, 09:21 PM   #16
Yes I will check it again I believe mine are 22.5 x 235 Michelin
I have to take air out but not sure if I have to remove the Tire Minder sensors first? Manual says everything except how to take air out??😜 Thanks
Dennis
Old 09-17-2017, 04:28 PM   #17
Tbonz's Avatar
Chart says 80.. I am doing 85.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
pressure, tire
