Old 08-04-2013, 11:41 AM   #1
327 electric slides
Just brought a used 2011 georgetown 327. As always it came with no information or equipment to manual retract the Electric slides. Every thing I read is about hyd. systems units ( my unit had Lippert jacks).
Help please
n119r is offline   Reply With Quote
Old 08-04-2013, 03:33 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Lippert Electric Slideout Manual.pdf
LCI - Electronic-Hydraulic-Leveling-and-Slideout-Manual.pdf
Lippert Slideout Manual.pdf:
This should have the info you want.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-04-2013, 07:50 PM   #3
Thank you for your reply.
I had looked at these three manuals. They do not appear to be what I have. I can not locate the motors or find where one could use a tool to manual extend the slides. Both slides have cables on each coner and appear to be connect via a drive type shaft on the lower part of the slide. There is no opening for a tool eather under the coach or inside and boy we have looked. Just listening to the motor on the bedroom slide it sounds as if it is located on top of the slide behind the wood facing with no access to the motorl
I have previous owned five r.v's all had slides but I have never seen one like these.
I am sure as always with me it is operator error! I will give it another try tomorow .
Old 08-05-2013, 05:15 PM   #4
leomosley's Avatar
I think this site is what you are looking for. There are links to manuals at the bottom of the page.
BAL - Innovative Products for the RV Industry
Cheers
Leo Mosley
2011 Georgetown 300S
leomosley is offline   Reply With Quote
electric, slide, slide out
