Old 10-01-2014, 09:55 PM   #1
334XLF Slide Interference Issue
We have a new 2014 Georgetown 334XLF, and were wondering whether anybody else that has a similar floor plan has our same issue. The 334 XLF has four slide outs. The main slide on the driver's side that contains the sofa and the dinette has an extremely small clearance on the rear of the slide with the cabinet doors above the main TV. In fact, the last time I retracted this slide, it impacted the cabinet door and would have torn the slide fascia apart if I had not stopped it in time. I had to remove the cabinet door to allow clearance to get the slide retracted. Has anyone else had a similar problem, or does anyone have a suggestion as to why the slide has evidently gotten slightly out of alignment to cause this impingement? Any suggestions as to a fix, other than more days in the dealer's shop?
2014 Honda CR-V
BobandDi is offline   Reply With Quote
Old 10-01-2014, 10:37 PM   #2
Iggy's Avatar
Sounds like the slide needs to be adjusted.
Get to dealer to make adjustments side to side for slide.
Iggy is online now   Reply With Quote
slide
