Old 08-10-2017, 03:59 PM   #1
335DS TV question
We have 3 tvs on our 335Ds; Furrion outside and in living area. Seiki in the bedroom. When I am on antenna I can program all 3 for channels. However, when we connect to cable only Furrion tvs can function. The Seiki can only program on analog and will not accept digital cable channels.
I contacted FR and they said to file a warranty claim with dealer to get replaced. Dealer did not agree with FR and basically didn't believe what I said. Anyone else have this issue with that crappy Seiki tv? Also, it is nearly impossible to access the bracket to even remove that tv.
exlnt1900 is offline   Reply With Quote
Old 08-10-2017, 04:03 PM   #2
BigHomey's Avatar
The SEIKI TV does not have a QAM tuner - only ATSC tuner. It needs the QAM tuner also to receive cable. (I had 4 of the SEIKI TVs in my MH.)
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is offline   Reply With Quote
Old 08-10-2017, 04:11 PM   #3
I Break Everything
mikel68's Avatar
We have 351DS, similar problems I replaced the switch box. This may not fix yours but all of our TVs work now. If this is the one you have, ours was cracked on the inside.
2015 Georgetown Forest River 351DS Class A
2008 Keystone Cougar 293SAB 5th Wheel
2007 Jay Flight 30.5RLS 5th Wheel
2006 Jay Flight 29BHS TT
mikel68 is offline   Reply With Quote
Old 08-10-2017, 04:42 PM   #4
minnesota65's Avatar
We have the same set up on our forest River Georgetown the same thing happens with us
minnesota65 is offline   Reply With Quote
Old 08-10-2017, 04:44 PM   #5
Forest river if your warrantee is done on your coach will not help you with nothing most useless company I've ever dealt with the TV set in the bedroom is a piece of crap just like you mention it will only download analog that's it
Old 08-11-2017, 06:46 AM   #6
Senior Veteran RV Owner
amullis's Avatar
I removed the Seiki TV from my 2015 GT 328TS and replaced it with a Vizio that can program cable channels. The Seiki was screwed into the wall from the rear (go through the access panel in the closet to unmount the Seiki). Once I had the Seiki down, I mounted a $35 Wall Mount hardware I bought off Amazon and mounted the Vizio TV the proper way! Forest River mounts those bedroom Seiki TV's with three wood screws instead of using a mounting wall bracket. Cheap hack job if you ask me!
Art Mullis
amullis is offline   Reply With Quote
Old 08-12-2017, 11:19 AM   #7
Tbonz's Avatar
Same here..Both tv work on antenna..Rear Seiki dont work on cable.
2017 Georgetown 329S
Toad 2015 Toyota Tacoma
Tbonz is offline   Reply With Quote
Old 08-12-2017, 03:32 PM   #8
JimF's Avatar
Sure glad we have a unit that came with matched Toshiba sets, never had a problem and can't identify with what you guys are going through. Glad we don't have your problems.
Safe Travels.
JimF, CWO, US Army Ret, 100% DAV
2011 Georgetown 378TS
2008 Dodge Caliber Toad
JimF is offline   Reply With Quote
