Old 02-20-2016, 03:48 PM   #1
351DS bedroom TV mod
Well, we decided to make some adjustments to our back TV, we wanted to replace it with a newer Samsung and also use the extra cabinet space behind it.
So first we took off the TV and removed the board that was behind it, leaving this nice open space.
2015 Georgetown 351DS
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
ChrisAndGarren is offline   Reply With Quote
Old 02-20-2016, 03:50 PM   #2
Then we added some crossbars to support the bottom of the new cabinet
Old 02-20-2016, 03:52 PM   #3
Next came the shelf, a piece of 3/4 inch plywood we had cut to size, stained and polyurethaned.
Old 02-20-2016, 03:54 PM   #4
After that, the sides which were 1/4 plywood, also stained and coated with polyurethane.
Old 02-20-2016, 03:56 PM   #5
Then we reinstalled the electrical box and added a hole for the coax.
Old 02-20-2016, 03:58 PM   #6
Next came the door we made, out of 3/4 inch plywood again, stained and with multiple coats of polyurethane.
Old 02-20-2016, 03:59 PM   #7
When closed. The hardest part was getting the hinges level!
Old 02-20-2016, 04:01 PM   #8
We have 2 latches to close, the simple pressure one for when we are parked, and a magnetic one for when we are driving.
Old 02-20-2016, 04:03 PM   #9
We also mounted the new Tv on the door, this is why we have 2 latches! Sorry it's sideways, but you get the idea.
Old 02-20-2016, 04:04 PM   #10
And the final result! We have to add a knob to help pull open the door, but we are done other than that.
bed, roo, modifications
