Old 05-15-2015, 09:19 PM   #1
jcw
351ds home theater problems
I have a 2015 351ds with the home theater option. We tried to play a dvd with the Jensen head unit in the front dashboard on the tv in the main cabin behind the dinette. While we had sound and picture, the picture was in black and white. I removed the main indoor tv and noticed it is only 3 cables into the Colorstream HD input, 1 left audio, 1 right audio and 1 composite video. I checked to make sure all connections were good contact. Using the Jensen head unit remote, I could not find a setting to force color output. Has anyone had similar experiences and found a resolution?
jcw is offline   Reply With Quote
Old 05-15-2015, 09:47 PM   #2
GABoy's Avatar
You need to switch sources on your TV. The jenson is sending red/white RCA witch is left/right audio and a yellow RCA witch is video. It's not high definition. Change video input on TV to correct source and all should be good.
2014 Georgetown 351DS
Chevy Colorado Crew
GABoy is offline   Reply With Quote
Old 05-16-2015, 05:35 PM   #3
jcw
That worked. Thanks.
heater
