Old 06-03-2015, 08:31 PM   #11
I pulled the cable heard were the noise was and cut a hole and was lucky I was right on it I just covered the hole with a plate
Grouch1
2013 Georgetown 351dsf
2011 Jeep Wrangler
Grouch1 is online now   Reply With Quote
Old 06-04-2015, 12:17 PM   #12
I had the same problem with my 2011 Georgetown 327DS. There should be a 4-way splitter behind the amplifier in the overhead and there just wasn't enough signal getting to the TVs. I connected the output of the switchbox to a single port amplifier which feeds the cable going to the splitter. This provided a needed signal boost for not only the antenna, but also the park cable and the aux inputs to the switchbox. Best of all, no cutting to get to the splitter behind the cabinet and there's AC power in the cabinet for the amplifier.
Phil
pmsherman is offline   Reply With Quote
antenna
