Old 09-12-2014, 11:38 PM   #1
351DS Water Filter
How do you unscrew the water filter thats in the exterior compartment thats next to the city water inlet, black tank flush, etc?
I tried using the plastic white socket thing but it didnt move. The whole filter and cap seems loosely mounted so I didn't want to use much force.
I'm just trying to drain it for storage. Thanks.
sithc is offline   Reply With Quote
Old 09-12-2014, 11:59 PM   #2
Most likely water pressure built up - open the outdoor shower valve and it should come off.
ttincali is offline   Reply With Quote
Old 09-13-2014, 07:11 PM   #3
jergeod's Avatar
You will need some pressure to get it loose.
George & Jerri
06 GT 340 TSSE
USMC
jergeod is offline   Reply With Quote
Old 09-13-2014, 08:20 PM   #4
Cornelius's Avatar
When you replace the filter cartridge, also replace the O-ring in the filter housing. The O-ring kit includes a small tube of silicone gel that is applied to the O-ring and makes future filter removal much easier. Home Depot sells the O-ring kits; they are located near the replacement filters.
2010 Georgetown 373
2013 Jeep Wrangler
Cornelius is offline   Reply With Quote
Old 09-14-2014, 12:32 AM   #5
You can get the KW1 filters at Home Depot?
Old 09-14-2014, 01:33 AM   #6
Cornelius's Avatar
My 2010 Georgetown 373 has a Water Pur CCI-10-CLW filter, which uses a standard size home water filter replacement. It's not a KW1 filter. I don't think Home Depot sells the specialty size KW1 water filter. They sell GE brand standard size filters and O-ring kits, which also fit home water filters made by other companies. I just bought an O-ring gasket kit yesterday for $2.48.
2010 Georgetown 373
2013 Jeep Wrangler
water, water filter
