Old 04-25-2016, 03:57 PM   #11
chrisbailey13's Avatar
Yes the Clarion has a remote as well. I think my coach came with a total of 8 Remotes.
4 for the large TV's
2 for the Bunk TV's
1 for the Clarion
1 for the Jensen
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 04-25-2016, 04:05 PM   #12
2 for the Bunk TV's
1 for the Clarion
1 for the Jensen
Clarion Remote looks like this
Old 04-26-2016, 09:48 AM   #13
Thanks so much, this will clear up what is the only issue we're having with the coach so far. I'll let you know later how I make out with the e-brake switch.
KennHC130 is offline   Reply With Quote
Old 04-26-2016, 02:55 PM   #14
OK, still at square one. CB, I unplugged the o'head tv from the box with the red/white cannon plug and plugged directly into outlet. Also unplugged cannon plug itself. No luck...still audio only warning on clarion monitor and no video screen on tv when input on video. Regular tv stations work just fine when input changed, even if engine on and in drive?? Any other suggestions greatly appreciated. The video root menu still comes up on living room tv but can't control/play it due to warning screen on clarion unit. Remote for it and Jensen unit outside confirmed missing after thorough search so will have to replace. That part's easy.
Old 04-26-2016, 04:47 PM   #15
OK..just to clarify. the disconnecting of the safety relay at the outlet allows the TV to be on while the engine is running. the issue you have with the video is at the Nav/Multimedia unit. there is a ground detection wire that is wired to the parking brake that needs to be connected to the chassis ground of the head unit. the easiest way to access that area is to remove the 6 screws that hold the plastic dash surround (with the radio, aux buttons, 12v outlet, and climate control unit) and slide it all out of place so you can see behind the head unit easily.
Old 04-26-2016, 05:11 PM   #16
Wow, thanks, I'll dig into it in the next couple days. Do you know what color wire and where it should be attached that I'm looking for. I don't consider myself and electronics whiz.
Old 04-26-2016, 05:12 PM   #17
BTW, is there a nav system available to install with this unit?
Old 04-26-2016, 05:32 PM   #18
The wire should be green.
Old 04-26-2016, 05:33 PM   #19
Which head unit do you have? Mine has Nav built in.
Old 04-26-2016, 08:13 PM   #20
Clarion VX 401
