Old 04-20-2016, 06:57 PM   #1
364TS Fridge Model
I know you are getting tired of this but you know the drill....
My unit is in storage and I need to order an ice maker for the bottom fridge. Can't ever have enough ice!
What model residential is in the 364TS?
2016 Georgetown 364 TSF
2015 FunFinder 242BDS traded for above
2014 Starcraft 1221 Comet traded for above
Modmike is offline   Reply With Quote
Old 04-20-2016, 07:26 PM   #2
AquaMan's Avatar
I can look in the morning if no one comes through tonight.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 04-20-2016, 08:46 PM   #3
toolman_57
FGHF2366PF5A
Electrolux
toolman_57 is offline   Reply With Quote
Old 04-20-2016, 08:48 PM   #4
Thanks! If anyone wants to add the second ice maker here is the description and part#. Counter depth is key.
Frigidaire (2nd) Ice Maker Kit for Bottom Freezer Counter-Depth 23 IMK0023A
Best price I found is on Amazon
If you are wondering why I am adding a 2nd ice maker, it's because the door one is anemic. We are 5 to 8 people and we love our ice.
Doesn't really cost you much extra energy because the freezer is already cold.
Old 05-04-2016, 02:57 PM   #5
Ok, my wife is about to be blow away. You're telling me I can add a SECOND ice maker to my 364ts residential size fridge? The door one never has enough ice made.
That link on amazon is to a $59 part that installs in the freezer area (not the fridge area) that will also make ice???
This seems too easy.....
2015 Georgetown 364ts
2016 Infiniti QX60 w/ Acme Tow Dolly
thebenz is offline   Reply With Quote
Old 05-13-2016, 11:00 AM   #6
I just installed the freezer ice maker and plugged in the wiring harness. I'm a little confused what let's it know to send water back there. So I have to get behind the fridge and mess with the water lines???
Old 05-13-2016, 11:02 AM   #7
It will make ice until it is full, then the metal bar will raise and stop the ice making process.
Old 05-13-2016, 11:08 AM   #8
Well, I mean what was keeping it from squirting water into the freezer before? Al I did was screw in the ice maker sitting under the water tube and plugged it in. I didn't know if I needed to open up any water tubes on the back of fridge.
Old 05-13-2016, 11:13 AM   #9
Oh sorry, although I haven't installed mine yet. I did install another one before and I had to run a water line.
Bear in mind that that is USUALLLY how it works but you mention there was a water line already in place. Is there a valve somewhere? What does the manual say?
Old 05-13-2016, 11:17 AM   #10
The instructions are vague on the water supply. It seems more like if you have never had water connected to it. I'm was hoping someone on here that had already done the instal could chime in.
fridge, modifications
