Old 07-07-2016, 06:08 AM   #1
kentdavido's Avatar
364TS Frigidaire Power
We have a full residential French door and out on our first trip. Once the Georgetown is fired up will it run off the inverter/batteries or is it Strictly generator power? It so what do you have to do?
Kent
kentdavido is offline   Reply With Quote
Old 07-07-2016, 08:35 AM   #2
swamprat26's Avatar
Inverter will run it and generator will run it. I run my Generator while traveling to run AC's
swamprat26 is offline   Reply With Quote
Old 07-07-2016, 09:58 AM   #3
RJJ
Make sure inverter is on. Mine has a button by the entry steps. When on, it will light up green and the Fridge will run on batteries. I leave mine on all the time, some people turn on/off when needed.
2015 Georgetown 329DS
2014 Chevy Equinox
RJJ is offline   Reply With Quote
Old 07-08-2016, 09:40 AM   #4
chrisbailey13's Avatar
You should have a button somewhere like this that will allow you to turn the inverter on without the GENSET or engine running
2014 Georgetown XL 352QS
2013-2017 Days Camped-215
chrisbailey13 is offline   Reply With Quote
Old 07-09-2016, 05:23 AM   #5
kentdavido's Avatar
Thank you all and we found the button. Your wisdom and advice is priceless.
power
