Old 08-26-2016, 06:05 PM   #1
364TS fuse box
Is there another fuse box somewhere that runs the outlets in the kitchen area (2016 364TS). None of the outlets work and I check all of the breakers and fuses in the panel above the king size bed. Anyone have any suggestions on what might be causing this? The forward A/C also won't kick on......
Melvinson404 is offline   Reply With Quote
Old 08-26-2016, 07:19 PM   #2
kentdavido's Avatar
Check the ground fault reset button on the master bathroom outlet. And the front AC should be controlled with ithe fuse panel above the master bed, and I believe it should be one of the front fuses on the right.
kentdavido is offline   Reply With Quote
Old 08-26-2016, 09:22 PM   #3
Yeah the front Ac breaker is set but still not working. I don't see an reset for bathroom outlet. It has a sticker that says GFI but no button that those outlets normally have.....
Old 08-26-2016, 09:44 PM   #4
The gfi is in the back bathroom on ours
Snoodledog is offline   Reply With Quote
Old 08-27-2016, 01:15 PM   #5
Yup, found it back there. It wasn't the problem though. There are two 30amp breakers on the actual generator itself. One of those was tripped. All back in working order now. Thanks to all that tried to help.....
fuse
