Originally Posted by jplacz2000
i have a 2106 gerortown 364ts has one 2000 inverter running refridge i want to run entire rv when parked had dealer in stall an ags was going to add two more batteries to existing 4 for coach any idea how to run to panel so i can turn on n ightlights or tvs without gen
There are a couple of things you will need to do.
1. identify what breaker controls the non GFI outlets in your coach. In my GT there is only one breaker for all outlets that are not GFI. it controls the TV's, and wall outlets.
2. find a place you can tap into that wire probably with a yellow coating so you can put a transfer switch between the breaker and the load. (Xantrex makes these) there may be a junction box in the storage bin with your power cord, or you might have one somewhere else in the basement area.
3. find a way to route the transfer switch power back to your inverter. these do not have to be close to each other, but you have to have a plan.
Here is the post of my install
http://www.forestriverforums.com/for...all-91636.html
