Old 06-11-2016, 03:21 PM   #1
364ts - Getting behind outside TV
I wanted to connect a Roku stick to my outside TV like I do all my other TVs but I can't for the life of me figure out how to get access to the HDMI port and plug it in. Any suggestions?
2015 Georgetown 364ts
2016 Infiniti QX60 w/ Acme Tow Dolly
thebenz is offline   Reply With Quote
Old 06-11-2016, 08:25 PM   #2
My outside TV comes out by pulling the TV up. I had to give it a quick pull up
There is an HDMI input on the side of my Tv
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 06-14-2016, 10:23 AM   #3
RVnut's Avatar
Ours was the same.. Just push up.. We took ours off so we could plug in a Fire Stick
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 06-15-2016, 04:52 PM   #4
I would advise using a hdmi cord with an adapter to change the stick or whatever you might want so you don't have to keep removing the tv.
cbmerton is offline   Reply With Quote
Old 06-16-2016, 11:05 PM   #5
Can I use Roku to project my smartphone onto tv without wifi? I have unlimited data and Netflix but I thought all these type things needed wifi. Would be awesome to stream my direct tv from phone to TV...
JLud is offline   Reply With Quote
Old 06-17-2016, 07:10 AM   #6
If you have an android you can use its "mirror image" setting and buy the adapter for it. Less than 15.00 at Walmart. At this time this is what I do.
I don't think you can sync a phones wifi and data to a smart device like Ruko or a smart TV at the same time.
2008 Honda CR-V
Old 06-17-2016, 12:17 PM   #7
As the others have already said, you can just push the tv up and remove it but I also added easier HDMI access to the tv by adding a wall plate to the side of the cabinet next to the sink. I have hdmi, USB, and earphone adapter to plug my iPhone in to listen to music on outside speakers or display whatever I need to on the outside tv using the HDMI input....
Name:	ImageUploadedByForest River Forums1466183710.707493.jpg
Name:	ImageUploadedByForest River Forums1466183764.244361.jpg
Melvinson404 is offline   Reply With Quote
