Old 08-18-2016, 03:09 PM   #1
364TS Height
Not sure if anyone has ever encountered a height problem with their 364TS (or other Georgetown for that matter) when it comes to shorter tunnels and bridges.
We want to travel from Delaware to North Carolina OBX. The Chesapeake Bay Bridge Tunnel has a height of 13' 6". Forest River has a listed height of 12' 1" for the 364TS. When I measured it to the highest point (the radio antenna) I get 13' 9".
Has anyone attempted this scenario? If so, what were the results?
2016 Forest River Georgetown 364TS
Browns-Camden is offline   Reply With Quote
Old 08-18-2016, 07:17 PM   #2
The antenna should be on a spring and therefore doesn't count for the actual height, there should also be a screw near the base so that you can lower the antenna.
Watertown is offline   Reply With Quote
Old 08-18-2016, 07:27 PM   #3
If you have the 22.5" tires, you may be at 12'10" (not counting antenna).
1930 lbs CCC
2014 Jeep Rubicon JK
steeljag is offline   Reply With Quote
Old 08-18-2016, 08:38 PM   #4
12'10"? !!!!! Seriously? Geez, I didn't realize it was that tall. I'll have to go check that out....
Melvinson404 is offline   Reply With Quote
Old 08-19-2016, 07:41 AM   #5
kentdavido's Avatar
Our 364TS has 22.5 tires and the specification says the rig is 12'-2".
kentdavido is offline   Reply With Quote
Old 08-19-2016, 08:30 AM   #6
Interesting, I don't think I looked at any unit with 22.5" wheels that was under 12'8" and most were 12'10". Maybe for Georgetown I'm just remembering the XL line ?
That height issue was / is important to me due to under roof parking I have measuring 12'8".
1930 lbs CCC
Old 08-19-2016, 08:59 AM   #7
NCCoachMan's Avatar
I didn't think they let RV's or trailers in the tunnel. Has that changed?
NCCoachMan is offline   Reply With Quote
Old 08-20-2016, 12:02 AM   #8
Just have to turn off the propane
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping
mogman is offline   Reply With Quote
Old 08-20-2016, 08:14 AM   #9
Tim & Lisa Trempert
13'6" is standard clearance height for trucks, RVs, etc. Unless you've added an after market roof item (satellite) that is higher than the A/C, you should be fine.
Tim & Lisa
2011 Georgetown 350
Trempert is offline   Reply With Quote
Old 08-20-2016, 10:02 AM   #10
Trempert is right, 13'6" is a safe bet. If you ever get a GPS get an rv specific device like Good Sam Rand Mcnalley and you can enter the height in the gps and it will steer you clear of low tunnel and bridge clearances.
Jim G is offline   Reply With Quote
