Old 03-26-2015, 02:13 PM   #1
toolman_57
364TS Propane Outlet
Has anyone connected a gas grill to the outlet port on the Georgetown? I'm trying to figure out what equipment I need. On my version there's an outlet on the passenger's side ahead of the rear bunkhouse slider that I'm assuming is designed for this purpose. It looks like some sort of quick disconnect. I purchased a small table-top grill that has the usual regulator and connector for typical gas grill propane tank. Thanks.
toolman_57 is offline   Reply With Quote
Old 03-26-2015, 05:53 PM   #2
It's probably a high pressure line and if the bbq you bought uses those little green cylinders then you need a regulator to step down the pressure.
MattL is offline   Reply With Quote
Old 04-01-2015, 11:16 PM   #3
toolman_57
Solved it--Here's the valve that's installed on the motorhome:
Model 250 Ball Valve Quick Connect X 1/4" FNPT - Natural Gas Quick Disconnects & Plugs
Here's the hose-end connector--I replaced the tank valve connector on the grill's regulator with this:
Model 250 Male Plug X 1/4" MNPT - Natural Gas Quick Disconnects & Plugs
propane, electrical
