Old 12-07-2015, 05:52 PM   #11
RVnut's Avatar
No problem using the generator while driving to watch TV.. Just remember to turn it off when pulling into a gas station.. The generator averages 8/10 of a gallon per hour of usage
As for the washer/dryer the dealer wanted $3200 to have it installed from the factory.. I found the same unit for $1000 (at PPL) they install and figured I could save $2000 by doing it myself.. LATER I TALKED TO FACTORY REP AND HE SAID ALL THEY CHARGE IS $1500 TO DO THE WHOLE THING.. So you should use these numbers and work it into the deal
364 Georgetown 2016
in Montana
RVnut is offline   Reply With Quote
Old 12-07-2015, 07:21 PM   #12
Yes, my rep just confirmed that $1500 for the unit installed.
Kevin M. is offline   Reply With Quote
Old 12-07-2015, 08:34 PM   #13
RVnut's Avatar
If they will hold the dealer to that then I would go for it.. I am not looking forward to lifting this 150 lbs when it warms up
364 Georgetown 2016
in Montana
Old 12-08-2015, 09:50 PM   #14
The F 53 has a TorqShift® HD 6-speed Automatic with Tow/Haul mode, not an Allison.
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring
FrankMor is offline   Reply With Quote
