Old 05-04-2015, 08:30 PM   #1
toolman_57
364TS Recliner Sofa Question
I don't know if we have a defective recliner or if it's designed to be the way it is. I reported it as a warranty item and will wait to hear from the dealer and FR. Here's my isssue...
The day we purchased the MH I pulled the lever, the footrest came out, and then I couldn't figure out how to push the footrest back down. Left it that way and reported the issue for them to clear up during prep.
When we did the walk-through I tried it again and had the same result. We didn't take delivery that day so I reported it again so that they could fix it up (along with other issues the dealer found right before walk-through).
Came back two weeks later and they showed me how the recliner works--they said we need to use the back of our heals and pull the footrest towards the seat and then the footrest will release. I tried this and it seemed to work OK, shrugged my shoulders and then drove it home.
After our first trip we found that none of us were able to reliably lower the footrests on the sofa. We either helped each other out by lifting up and pushing in the footrest (helper) while the person seated lifted their legs up. If the person enjoying the recliner didn't have help they had to find a way off the couch (think kids playground and the slide) so they could use their hands to release the footrest so that it could be lowered. Not fun for the over 60 crowd.
So is this an anomaly or does yours work that way as well? I think FR uses this recliner sleeper sofa in other models than the 364TS.
toolman_57 is offline   Reply With Quote
Old 05-05-2015, 10:49 AM   #2
Iggy's Avatar
This is like many recliners. I have them in my house and I have to push them back in with my heal to lock in place.
Old 05-05-2015, 12:29 PM   #3
This is consistent across numerous brands of motor homes. I couldn't figure it out either then someone showed me you just put a little upward lift on the rest from the top and it closes easily.
thebenz is offline   Reply With Quote
Old 05-07-2015, 08:09 PM   #4
Yes, you have to use your heels to pull the footrest in toward you a bit before you can push it back down. Ours is working fine, however, when we tried the footrest on the display model at the RV show, it kept getting stuck. The Forest River guy at the show taught us how they work, but it was sticking a bit from people trying to force it down.
Debbie
Georgetown 364TS
Fantastic husband, 2 daughters, 2 foster sons and 3 pups
http://worldofweeks.com/
2xaround is offline   Reply With Quote
Old 05-14-2015, 09:22 PM   #5
It might help to oil the mechanism. I don't have any problems, but my wife does, and she hates it. We are installing a power love seat recliner, with an end table to make up the 130 inches of available space. Problem solved!!!
Roger2650 is offline   Reply With Quote
Old 05-15-2015, 07:22 AM   #6
BillMFl's Avatar
I removed my pull out sleeper sofa and like the extra space. Moved the Euro Recliner there and added book case/end table next to the chair.
BillMFl is offline   Reply With Quote
