Originally Posted by Melvinson404
Newbie here. I have a 2016 364TS. The switch panel right across from the bunks which has the water heater switch has a red light next to it (it says reset underneath it) When I turn the water heater on, the red light goes on but it turns off after a few seconds. Is this light supposed to stay on?
Also, am I supposed to turn water pump on only if I am using the fresh water tank or should I be turning it on even when on city water?
The gas water switch when turned on makes the light turn on until it lights.
I guess if you have any issues and it doesn't ignite the light will stay on.
So it should come on for a few seconds then goes out is normal operation.
Water pump should only be turned on when dry camping without any city water hooked up.
Also you have a electric element that is turned on outside at the lower left corner after your remove the panel.
This should be only used when you have sufficient water supply in the tank or have city water hooked up. If hot water heater is not full you may burn out the electric element.
I have attached the manual if you don't have it.
Hope this helps you understand its operations.
