Old 05-24-2013, 06:51 PM   #11
Iggy's Avatar
Originally Posted by herk7769 View Post
Your sensors and tank wall are dirty/slimy.
You can try a sensor cleaner, but I had better luck just replacing the sensors with Horst Probes.
Horst Miracle Probes for Wastewater Tanks in Recreational Vehicles RVs
Horst Miracle Probes Demonstration by Jim Grich of AmericanRVer - YouTube
Horst tank Probe Installation
OK Lou. I have read your previous removal and install of the new probles.
Now be honest. Since you installed have you ever gotton any false readings in either tanks?
Old 05-24-2013, 07:12 PM   #12
Herk7769's Avatar
Never the black tank since the install. Standard 1 cap Calgon;1 cap laundry detergent.
No so lucky with the gray tank. Something got on one of the gray water sensors (the spiral ones) and the 1/3 light has been intermittently stuck ON when empty last year.
Troubleshooting the MicroMonitor
If you remember from the article I did on the MicroMonitor system, the resistance on ANY probe to the ground probe only has to drop from infinity (open circuit) to less than 188K Ohms to turn on the 1/3 light.
It has been stubbornly resistant to sensor cleaner. I think I have a hair ball caught on the spiral. When I get back from Cape May I am going to drop the panel and meter the probes to find out which one is my problem.
If I had it to do over again (and I still might) I would spend the extra 10 bucks and put black water sensors (the one with the shielded wire) in the gray tank too.
HAM CALLSIGN - KC3FFW
Old 05-24-2013, 07:49 PM   #13
John McClain's Avatar
After dumping: About every three trips or so. I add about 10 pounds of ice and about two gallons of water and 1 cup of simple green in the black tank and 1 cup of simple green to the gray tanks. On the drive home it seams to slosh around and clean the tanks up. I am on my third rig now and have never had to replaced a sensor yet !
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 05-24-2013, 07:56 PM   #14
Herk7769's Avatar
When I swapped out the probes for the Horst unit, this was what the GRAY tank probes looked like.
Name:	Horst Probe Install 044.jpg
Old 05-24-2013, 09:29 PM   #15
VinceU's Avatar
Originally Posted by SaladoBob View Post
This rig is brand new so I may have to take it back to service. Guess as long as I know the level, it should not be a big issue.
Just a suggestion, if you blast the tank once a month with a tank "rinser" from Wally World for about $9.00 it'll keep the tank probes working. I made one from plastic pipe for about $5.00. Just direct the nozzle towards the sensor end, 2 minutes of cleaning they are working!
