Old 03-21-2012, 06:47 PM   #31
VinceU's Avatar
Fridge Problem
Heres a dwg. from Forest River (Adaption of RV Custom battery control) showing two terminal blocks at bottom. Fuse #4 on right block supplies the Reefer doors lock coil. Its fed via blue wire to Dometic input TB at back of fridge. The box normal 12V supplies the opening voltage. Note the blue lead is only energized when the chassis ign. switch is on.
Hope this is helpful.
Old 03-21-2012, 08:20 PM   #32
We bought ours in Aug 2011 brand new. We have the Dometic 4 door water on left door ice on the right (in the freezer). We have a 378. Today we got a recall on the truck itself. Does anyone know about the awning. The hydraulics are rusted already. Glad we bought it new. I hate to see this thing in 5 years. Sad.
lyndapinard is offline   Reply With Quote
Old 03-22-2012, 10:04 AM   #33
2012 Georgetown 378
raycyn778's Avatar
Vince, thanks so much. Do you have the fridge ignition lock set up on yours? And does it work? Which fridge do you have? I just picked up my coach from my dealer for warranty work and they say that they called FR and they said that they (the factory) do not hook this option up on their RV's. Sounds hard to believe. do you know anything about that?? They are going to replace my fridge as they were unable to get the door dispensors to work and FR is replacing it...and if it is supposed to be working, I am going to get on them to hook it up when they install the new fridge....i think it is a great safety feature as we have already had a fridge door open and milk came flying out while we were traveling
Ray
Ray, Cynthia, Duncan and Bailey
2012 Georgetown 378
2006 HD Ultra
1992 Fat Boy
raycyn778 is offline   Reply With Quote
Old 03-22-2012, 11:32 AM   #34
armye7's Avatar
I have a 2012 Georgetown 378xlf and my switch is hooked up
armye7 is offline   Reply With Quote
Old 03-22-2012, 11:33 AM   #35
armye7's Avatar
Factory must of hooked mine up
Old 03-22-2012, 02:04 PM   #36
VinceU's Avatar
Wow dejavu! My dealer also told me locking door not available on Gas chassis Amazing cause FR routed the wire and paid for the feature of locking!
Yes mine is now working and is quite handy. I have a 2012 387 with Dometic 4 door model 1350 wim which stands for Water and ice maker. The only difference is the water is on the door, the ice is by tray only. The problem with mine was the alt wire leading up the box to the latch was parted during installation (another dealer). Tell your dealer must have 14 volts on power terminal back of box with engine running. BTW this refrig is $3500 discount retail, great when it works!
Old 03-22-2012, 05:22 PM   #37
Send a message via Skype™ to Falcon35
My lock works and worked from day one. Dometic has a real quality control problem.
The dealer replaced the one that came from FR and the new one the freezer door still leaks and there going to fix it for me when we stop in at Elkhart.
2012 Georgetown 378TS Fire Mist
2008 Honda Fit
ReadyBrake™ Surge Brake System integrated with ReadyBrute™ Elite RV Tow Bar
Protect-A-Tow
Falcon35 is offline   Reply With Quote
Old 03-22-2012, 11:01 PM   #38
nemo45's Avatar
Send a message via MSN to nemo45 Send a message via Yahoo to nemo45
Know what about the awning? Also, don't understand what you mean about the hydraulics being rusted. The recall on the chassis is no big thing. Getting mine fixed on the way home from south texas. We've lived in ours full time since Aug. 2010 and are mighty happy with it.
Don & Carol Niemeyer and Sandy
2006 Gulf Stream Tour Master Diesel Pusher
2011 Chevy Equinox Toad
nemo45 is offline   Reply With Quote
Old 04-18-2012, 11:16 PM   #39
Iggy's Avatar
Pictures are worth 1,000 words
ID:	12364   Click image for larger version
ID:	12365   Click image for larger version
ID:	12366   Click image for larger version
Old 04-18-2012, 11:18 PM   #40
Iggy's Avatar
More pictures
More pictures of RM 1350 4 door refrigerator
ID:	12368   Click image for larger version
ID:	12369   Click image for larger version
ID:	12370   Click image for larger version
ID:	12371   Click image for larger version
