Old 01-10-2014, 08:59 PM   #11
Mine just had a coupling I had to take the wall cover off in that compartment to get to it not bad only about 3 screws on the plastic cover only reason I saw it was I ran a hdmi cable from tv to front compartment which was kind of a hard job for me but anyway when the picture went bad I tightened it and picture came back
kgreen is offline   Reply With Quote
Old 01-10-2014, 09:03 PM   #12
They usually don't do a good job tightening those connections or they just come loose I have tightened every connection that I have found and they were not very tight it was the same way in the fifth wheel I had before MH
Old 01-10-2014, 09:09 PM   #13
kgreen thanks. I also put hdmi cable on the fp TV and the outside tv. The fp tv was a bear.Had to pull on left side of TV to do it. Didn't feel like taking all those screws out thanks again. Oh yea if you take that little panel offthe side of fp there Iis a splitter there that feeds the fp TV and outside tv.
RVINSMCM is offline   Reply With Quote
Old 01-10-2014, 10:39 PM   #14
Rvinsmcm thanks & good luck
Old 02-11-2014, 08:41 PM   #15
Sorry it's been a while since I had a look at my initial post after I couldn't find splitter over passenger cabinet. I'd resigned that I'd have to turn it over to a repair shop. But today I happened to be rummaging around the 2nd storage compartment on passenger side and low and behold noticed as KGREEN pointed out the cable to front TV had come loose from cable coupling. After tightening up connection I was back in business - will take off back cover tomorrow and see if splitter to back TV might be close by
Nomore9-5 is offline   Reply With Quote
Old 02-17-2014, 02:14 PM   #16
finally got out to rv today. looked for coupling where kgreen suggested. found it and tightened it.. followed that coax going toward the engine compartment and foud another coupling for the coax on the outboard side of battery! its taped up with electrical tape. will check that connection in the morn. still looking for the splitter that goes to bedroom tv. thanks to everyone working on this...
Old 02-22-2014, 07:01 AM   #17
Has anyone found the splitter for the rear tv yet?
Old 02-22-2014, 07:36 AM   #18
Hey kgreen. Finally some good weather. Will be looking for it today.will be starting from back to front. Will let ya know if I find it
Old 02-22-2014, 07:38 AM   #19
Good deal hope you can thanks
Old 02-22-2014, 02:29 PM   #20
Gave up. searched all under rv and no luck. if anyone finds it do let us know! short of taking off panel by antenna booster i have no idea. good luck. seems like no two gt378's are built alike!
378ts
